Hi, first post.First of all I've tried my best to do my homework, I've spent many hours this week trying to figure this out, and searching around here and elsewhere, so even if I'm being dense I would appreciate any help.
With multiAVCHD I can't create AVCHD with more than one audio track or with subtitles. The log shows that the subtitles aren't even sent to tsMuxeR. (But if I select the Panasonic BR player profile instead of the Viera TV one the log seems OK and the "tsMuxeR meta" includes all the tracks, but the same problem happens.) If I use tsMuxeR instead of multiAVCHD it's all good, the stream includes the tracks and I can play them on the PC, but then my TV doesn't understand tsMuxeR's flavor of AVCHD--and besides I think it can't bundle several videos into one AVCHD disk, like multiAVCHD can?
The following is something I posted on multiforum.deanbg.com, although it hasn't been approved yet, but it has all the information:
__________
I think I have done my homework, I have installed all the requirements (and I have installed on C:\multiAVCHD\), I've read everything I've found, and I pass the multitest. I have Vista x64.
The video is good and so is the first audio track, but the second audio track and the subtitles aren't added correctly, even though I don't see anything strange in the log (pasted at the end)--except for the frame reference count non compliance, but I don't know if that's got more to do with the video, which results and is played by the TV perfectly. At any rate I have tried transcoding to change the reference frame count, but the result is the same, even if there are no errors in the log then.
At the start of the job, the program sounds a very loud alarm. Is it because of some other problem that's not marked in red in the log, or is it supposed to be a feature?
If I click on the file in the Media tab to see the properties, the Haali splitter takes half a minute, and if I right-click on its tray icon I can see the two audio tracks and the subtitles one. They are then also listed by multiAVCHD in the properties. But then when the job is being finished, the Haali tray icon goes back but when I right-click on it, the subtitles track is no longer there--both audio tracks are still listed. I have tried the version of Haali downloaded from here, as well as the most recent one, and I have tried enabling "autoload VSFilter".
The log reports "2 audio tracks and 0 subtitle tracks". If I inspect the resulting .MTS stream file with MediaInfo, it says there's a video track and two audio tracks, but no subtitles track. If I play it on the computer with MPC, this recognizes one audio track only, and it does recognize a subtitles track, but labeled "No subtitles" (instead of the subtitles option being grayed out, as usual when there are no subtitles. And I can open the Subresync of MPC (which I can't when there's really no subtitles track), but it shows this subtitles track completely empty. If I play the output on the TV (PAL Panasonic Viera) from a SD card, the TV reports two audio tracks, but switching to the second one fails (it takes half a minute, and then the same track as before is heard) The TV reports no subtitles.
There is something else I've observed, although I don't know if it happens to everyone and is unrelated. I can't move or delete the output folder unless I close the program, and Process Explorer shows these dangling handles, after multiAVCHD reports having finished:
[attachment=0]dangling.png[/attachment]
And this is the log:
Code:[00:44:23] Initialising... [00:44:23] Checking for new version... [00:44:23] You have the latest build. [00:44:23] Consistency check finished! [00:44:23] Initialization finished. multiAVCHD is ready! [00:44:23] 2 years and 159 days since multiAVCHD was published. [00:44:23] 450 people supported it with donations [00:44:23] and you are the 24456 one to launch the program... [00:44:23] Support multiAVCHD to extend its features and keep it going! [00:44:23] multiAVCHD.dat version: [04010767] [00:45:21] Checking for available space and drive types (FAT32/NTFS)... [00:45:22] Destination [C:]: NTFS, 535245.18 MiB (522.7 GiB) free space [00:45:22] Temp folder [C:]: NTFS, 535245.18 MiB (522.7 GiB) free space [00:45:22] Log started for multiAVCHD v4.1 (build 770) [00:45:22] Selected output mode: Panasonic Viera TV / Camcoder (SDHC) (PAL) [00:45:22] Processing one title... [00:45:22] Processing (C:\Users\Javier\Desktop\Viera\test.mkv)... [00:45:22] Detected frame reference count: 8 (max:5). [00:45:22] Video is not AVCHD/BDMV compliant! [00:45:22] Detected video: ID#1:V_MPEG4/ISO/AVC 720x540, fps=23.976, ref=8 [00:45:22] Detected audio: ID#2:A_AAC (48000Hz 16bit 2ch 128kbps) Language: eng [00:45:22] PAL speedup will be applied to all streams for Viera PAL compatibility! [00:45:22] Attempting to convert A_AAC audio track #2... [00:45:22] Encoding A_AAC to AC3... [00:45:38] Trying to encode audio with ffmpeg... [00:47:21] Audio encoded to AC3 successfully! [00:47:21] Added audio: A_AC3, "c:\multiavchd\_temp\multitemp-20110603\test.t2.ac3.scn.ac3.scn.ac3", lang=eng [00:47:21] Detected audio: ID#3:A_AAC (48000Hz 16bit 1ch 128kbps) Language: jpn [00:47:21] PAL speedup will be applied to all streams for Viera PAL compatibility! [00:47:21] Attempting to convert A_AAC audio track #3... [00:47:21] Encoding A_AAC to AC3... [00:47:37] Trying to encode audio with ffmpeg... [00:49:20] Audio encoded to AC3 successfully! [00:49:20] Added audio: A_AC3, "c:\multiavchd\_temp\multitemp-20110603\test.t3.ac3.scn.ac3.scn.ac3", lang=jpn [00:49:20] Video height (540) not compliant (480/576/720/1080)! Final output may be distorted. [00:49:20] M2TS stream split set at 4000MiB... [00:49:20] Creating clip and playlist info (tsMuxeR)... tsMuxeR (Version 1.10.6) output: =============================================================================== Decoding H264 stream (track 1): Profile: High@3.1 Resolution: 720:540p Frame rate: 23.976 H.264 manual setted fps not equal stream fps. Change H.264 fps from 23.976 to 25 H264 bitstream changed: insert nal unit delimiters H264 bitstream changed: insert pict timing and buffering period SEI units Decoding AC3 stream (track 2): Bitrate: 128Kbps Sample Rate: 48KHz Channels: 2 Decoding AC3 stream (track 3): Bitrate: 128Kbps Sample Rate: 48KHz Channels: 2 B-pyramid level 1 detected. Shift DTS to 2 frames H264 bitstream changed: insert SPS/PPS units Processed 29832 video frames Creation of Blu-ray playlist Creation of Blu-ray stream info and seek index Mux successful complete. Muxing time: 2 sec =============================================================================== =============================================================================== tsMuxeR meta: =============================================================================== MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000 --split-size=4000MiB --vbv-len=500 V_MPEG4/ISO/AVC, "C:\Users\Javier\Desktop\Viera\test.mkv", insertSEI, contSPS, track=1, lang=eng, fps=25.000 A_AC3, "c:\multiavchd\_temp\multitemp-20110603\test.t2.ac3.scn.ac3.scn.ac3", lang=eng A_AC3, "c:\multiavchd\_temp\multitemp-20110603\test.t3.ac3.scn.ac3.scn.ac3", lang=jpn =============================================================================== [00:49:23] Media transfer: 00000 -> 00000.m2ts [00:49:23] Processing playlist... [00:49:23] Title #1 added: "test" [00:49:23] Non-compliant title. [00:49:23] Verifying title... [00:49:26] Title has: 2 audio tracks and 0 subtitle tracks [00:49:26] Preparing authoring information... [00:49:26] Authoring menu (PAL). [00:49:26] Creating title thumbnails for 1 titles (XMB)... [00:49:32] Using 1 thumbnail/chapter links for title #1... [00:49:32] *** Extracting 1 chapter thumbnails... [00:49:32] *** Chapter #1 [00:00:00.000] set for thumbnail at [00:10:21.500] [00:49:40] Image processing for XMB menu completed! [00:49:41] Setting main menu for 1 titles... [00:49:41] Playback will start with title #1 (test). [00:49:41] Setting menu properties... [00:49:41] Processing clip (CPI/CLPI) files... [00:49:41] Completed. [00:49:41] Applying Panasonic SDHC for TV parameters... [00:49:41] Preparing AVCHDTN database... [00:49:41] Database and index created! [00:49:41] Setting FAT compatible 8.3 filenames... [00:49:41] Done! [00:49:41] Saving multiAVCHD quick-load project (mpf): [00:49:41] C:\Users\Javier\Desktop\AVCHD\multiAVCHD.mpf (OK!) Compilation summary: Format: Panasonic Viera TV / Camcoder (SDHC) (PAL) Name : multiAVCHD =============================================================================== 1. test [00:19:53] =============================================================================== Overall duration : 00:19:53 Output size : 127 MiB (0.124 GiB) [00:49:41] C:\Users\Javier\Desktop\AVCHD folder created (AVCHD/Blu-ray output)! [00:49:41] Copy C:\Users\Javier\Desktop\AVCHD to X:\PRIVATE\ of SDHC/SD/MMC card. [00:49:41] or SD_VIDEO and PRIVATE to root of your SDHC/SD/MMC card. [00:49:42] You may now remove temp folder (C:\multiAVCHD\_TEMP\multiTEMP-20110603\). [00:49:42] Your compilation contains 0hrs 19min 53sec of video material. [00:49:42] multiAVCHD finished in 260.272 seconds (00:04:20.271)! [00:49:42] End of log. [00:49:42] Cleaning up... [00:49:42] Done! =============================================================================== [00:49:42] For technical support, bug reports and questions: [00:49:42] http://multiFORUM.deanBG.com/ [00:49:42] http://multiAVCHD.deanBG.com/ [00:49:42] http://multiAVCHD.deanBG.com/doom9/ [00:49:42] For latest download links and tools visit: [00:49:42] http://multiFORUM.deanBG.com/downloads/ ===============================================================================
I suggest you to use avchdcoder. Quality-wise it's better since it calculates output size (=bitrate) better, meaning when your project with mavchd ends up to 4.19Gb example, avchdcoder does it 4.36Gb. I have done many projects with avchdcoder that includes multiple subtitles / audio tracks, without problem. Just need to make sure that audio is without mark "header stripping" cause tsmuxer failures otherwise.
Thanks.
Although now I bought a media player dirt cheap, so I no longer need to convert to AVCHD. But if I find the time I'll check if AVCHDCoder does my TV.
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
How do you do main movie hd-dvd to avchd in multiavchd with 2+ audio tracks
By yoda313 in forum Video ConversionReplies: 2Last Post: 27th Sep 2010, 21:18 -
Converting .ogm to mpeg-4 with subtitles and multiple audio tracks
By Weasel3689 in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2009, 12:34 -
mkv - deleting multiple audio tracks & subtitles - then convert to avi
By fme008 in forum Video ConversionReplies: 2Last Post: 24th Mar 2009, 07:12 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28
