I have dl'd many .avi's and have encoded them. I recently downloaded a .bin file. I checked the site on this and it says to check the .cue file and to burn this. I do not see a .cue file. Do I need to extract the .cue file from the .bin file? If so, what do I use?
Thanks for any suggestions.
kingrdr
Results 1 to 9 of 9
If you want to see what's inside the bin files, and you don't have the cue file, I suggest you get Isobuster, or check out www.daemon-tools.com Isobuster will let you extract the MPEG files inside the image. And Daemon Tools will let you use the bin as a virtual drive. I would also recommend CDMage (those i mentioned without link can be found by searching on Yahoo!), which let's you make a new cue file. Check them out, and get a bit familiar with them
Forgot to tell you, to burn the bin/cue file, you can either use the latest version of Nero, CDRWin, or Fireburner. The mayority of the current burning programs support burning bin/cue files. You can burn the bin alone, but the .cue is necessary to tell the burning program how to exactly burn the .bin file.
I burned the .bin with Nero, but the cd was empty. I read that I need to burrn the .cue file, which I will try to extract using the programs you named. Thanks for the info.
If you're going to burn the .bin with Nero, make sure you select Mode 2 (I'm assuming it's a VCD or an SVCD). This will burn it the right way and show you the files, but it will not burn the movie correctly because VCD's and SVCD's use 2 tracks. In the first track lie the configuration files that will tell the player how to play the movie. But in the second track lies the movie file. This is where the .cue files comes in. The .cue files tells the program where each track lies on the .bin files, and the tracks will be arranged in the CD when burnt. That is why the .cue is so important (even though it's a quite simple text files).
you cant extract a cue file .you can extract the mpg though I believe virtua dub can do this for future reference d'load the cue file and the bin they are two seperate files.
Assuming that it is really a BIN image of a S/VCD, you can regenerate the "CUE" file by using VCDImager...
Extract the BIN file with VCDXRIP and then immediate "rebuild" the VCD as a CUE/BIN image by using VCDXBUILD on the outputted XML file. Both these are command line tools but VCD Easy contains a GUI for both.
You can then correctly (and safely) burn the CUE/BIN image of the S/VCD (including any menus and PBC goodies inside).
Regards.Michael Tam
w: Morsels of Evidence -
Virtualis -
Your process worked great. I used VCDEasy to re-create the bin/cue and successfully burned the movie.
Thanks for your help!
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
recover files from recycle bin
By Tbag in forum ComputerReplies: 5Last Post: 25th Jul 2008, 07:16 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
