Need to capture about 50 Video 8 tapes at the best resolution possible.
I bought the blackmagic shuttle to do this and had the original camera, but it cant capture the video as it flickers black then image then black again and so on, impossible to capture
1. Do i need a TBC to eliminate the flickering?
2. What other hardware do i need?
3. Video 8 player with a TBC
4. you tell me?
5. I have a mini DV camera Panasonic MX-8 should i just use this to capture then input via firewire?
6. Would inputting into a Marantz 7001 reciever then HDMI into the shuttle can u upscale it? does that help?
It says Up-Conversion (w/TBC) to HDMI with 480I/480P Converter
I will want to do about 50 VHSC Video camera tapes after as well.
I really only want to do this once so the best way and resolution would be best, price is a concern but not so ill have to do again hopefully.....
thoughts?
cheers
As in, didn't fix it, or you got no signal? I know my AVR always uses HDCP on the output regardless of source.
VHS capture hardware (again)
By ccooper in forum Capturing and VCRReplies: 37Last Post: 25th Nov 2009, 13:25 -
By Tom` in forum Capturing and VCRReplies: 12Last Post: 16th Jun 2009, 15:42 -
Capturing SWF Stream, Results in Taunting Server Admin Video
By smartwhois in forum Video Streaming DownloadingReplies: 1Last Post: 27th Jun 2008, 11:31 -
Capture 8mm/VHS > DV, recommendations for hardware
By nutshellml in forum Capturing and VCRReplies: 4Last Post: 21st Mar 2008, 21:07 -
best hardware + s'ware for bulk vhs to file capture & archiving
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 8th Sep 2007, 20:05
