Hi all,
I just purchased the TC-P50S30 and was wondering if anyone knows of a calibration setting for it...as in what my picture settings should be set to for close to real world. I've scoured the webs with no luck. Anyone else have this TV and have a custom picture setting for it? Thanks in advance!
dbanimal
Results 1 to 10 of 10
dbanimal
I'm in the same boat like you ( got the Panasonic VIERA TC-P42X3 few months ago from amazon) did you check http://www.avforums.com/forums/plasma-tvs/ ?
or this link
http://www.avsforum.com/avs-vb/showthread.php?t=948496 -
I recently did some calibration on my older lcd hdtv. I first used the basic thx optimizer found on a lot of dvds including the star wars dvds. It did a good job but I wanted more.
I got the bluray disc verison of the digital video essentials hd version. It has extensive test patterns and tutorials on what to set and adjust and tweak. It also comes with a filter pack that has different color filters to look through to manually adjust the smpte test pattern screen.
I love my results. I use a ps3 through hdmi on my set and the calibrated settings make dvds and blurays look outstanding.
I even did the audio tests a little bit and found out I have been doing my surround (pre hdmi 5.1) incorrectly. I had the front speakers set to LARGE instead of small. This was weakening my bass output to the subwoofer (a sony 50 watt model). I switched all my speakers to SMALL and noticed a whopping improvement in the bass on the subwoofer. Whopping might be exageratting a little bit. But I noticed a definite increase in deep throbbing bass that was lacking before. I thought it was merely a factor of the wattage of the subwoofer.
For me that was worth the 30.00 or so for the bluray and then some! I'd check it out and see what you think for yourself. There is a whole website that the manufacturer of dve makes for showing what it does and doesn't do.
OR go to best buy and pay 200.00 or more and have a "pro" calibrate it properly using professional tools.
I personally would go the 30.00 route and by the dve bluray disc.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Well I placed an order for DVE from Amazon, should be here in a week. Wish me luck!!
dbanimal -
dbanimal
VHS to PC Capture Calibration ...
By JasonCA in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 22:41 -
Power Calibration Area Error
By zork152 in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Jul 2009, 17:27 -
TV calibration via Spyder2 and that old nemesis: cables
By sanlyn in forum DVB / IPTVReplies: 9Last Post: 30th Jun 2008, 12:51 -
Guide for Greyscale calibration
By Vrex in forum User guidesReplies: 0Last Post: 15th May 2008, 19:01 -
LG DVC9800 - Laser Calibration
By firebird-jpx in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2007, 07:03
