I am trying to use the Koyotesoft HD converter to convert MTS video files to avi. These will be edited and then converted to NTSC .mpg for burning to dvd. The default frame rate is set at 25 fps but it seems to me that I should be using 29.97. Am I right?
Leave the frame rate at 25 fps. After converting to MPEG 2 for DVD use DgPulldown to add pulldown flags for 29.97.
Or slow the video to 23.976 fps. Then encode as 23.976 fps with pulldown flags -- like most NTSC movie DVDs. -
I have a problem. Due to a fatal error I\m forced to close down windows, and ultimatly leave out. Because leaving off for
boot procedure cuts off outside link from my computer, I will have to ask smt pretty straight forward
Are you kind to feed in a picture of Koyotesoft HD converter menu because next time I will lose program name and may
find it nowhere else but here. -
you can get the software from http://koyotesoft.com/. Not sure how to send you an image of the converter menu. Hope that this helps. Good luck
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 04:42 -
Converting from mts to MPEG 2 I-frame HD in an AVI container
By shaunthesheep in forum Video ConversionReplies: 68Last Post: 8th Jun 2011, 08:08 -
Help converting mpeg type video with correct frame rate
By DJX in forum Video ConversionReplies: 0Last Post: 9th Oct 2010, 19:24 -
Pinnacle Studio 12 frame rate error for Panasonic AVCHD Lite mts files
By dewispew in forum EditingReplies: 10Last Post: 13th Jul 2009, 03:13 -
Getting the wrong frame rate with mts files.
By tomhanks in forum Software PlayingReplies: 8Last Post: 24th Jan 2009, 18:02
