How can I add a small clip or an image that will stay for 5-10 sec, after which the video will start...
it's like a clip before the actual movie ... i can't explain any better
there is a plugin for virtualdub for this stuff?
Results 1 to 20 of 20
It's called joining or File->Append in virtualdub or avidemux . But the clip must match the source properties exactly or you have to reconvert everything.
hmm ...
and how to i make a new avi segment?
what program ?
this i really don't know -
Why'd you ask how to add a video to the beginning of another video if you don't even have the video you're going to add?
As Baldrick said, the new clip has to exactly match the properties of the original clip. This is exponentially harder than just making a clip. Which you don't know how to do. Better you forget the whole idea. -
Might there not be other ways to approach this, where you don't need to match properties for anything ? Using something like CX2D, or AVStoDVD, or DVD Flick ? I've long had it in mind to be able to structure a disk I made like this:
Short intro clip plays right away, then
It goes right into the standard disc menu for whatever else is on the DVD.
I could be mistaken, but that does not sound too far removed from what the OP was describing. And it seems like I am only missing a couple of not-very-major steps for being able to do this -- perhaps with either of those first two programs, with which I am already familiar. The learning curve on using them is not terribly steep for a new user, either.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
i have the clip i want to join..
but i noticed that in virtualdub i can't click on
Append AVI segment
i have version 1.9.11 -
hmm ...
i see..
it seems my second clip has a different framerate
edit:
hmmm
now they are the same but i get the same error
http://img32.imageshack.us/img32/656/errortn.pngLast edited by DeNeDe; 3rd Jun 2011 at 13:14.
As said before, all characteristics have to be exactly the same. You're only showing 5 decimal places in that screenshot
The NTSC film framerate is actually 24000/1001 or 23.976023976024000....
Change one to match the other
video=>frame rate try something like 23.97602 should be good enough, then direct stream copy for audio & video & save them out, then re-import and append -
i can't do two encodes..
the first video i have has 23.976 but it says it is 23.97599
this video i encode with sub + other effects and it takes me like 35min
i can't do it all over again just to put another clip in front of it and as u can saw in the picture.. the fps are exactly the same. -
But it's not exactly the same, that's why you can't join them
It's not 2 encodes. Direct stream copy is copying, not encoding (takes seconds or minute). It' s just changing the fps header. The timing won't be off - difference between 23.976 and 23.97602 won't be perceptible for 35 minute episodes. Or change them both to 23.976 exactly if you want. The point is they have to match EXACTLY. Everything, not just FPS.
Or try avidemux, it's better with slightly off frame rates -
1) Load your first clip
2) File=>append , select your 2nd clip
3) Set the video=> copy , audio=> copy, format=>avi on the side drop down menus
4) CTRL+S to bring up save dialog, enter name with extension e.g. "joinedvideo.avi" , press save -
i did this..
and it puts the 2nd clip at the end of the 1st
i need it at the very beggining -
swap the order then
I just tried it . Works for me
Maybe you're using a bad version ? Try another build -
it is the latest version ..
how to swap the order?
i don't know anything about this program -
load the 2nd video 1st then append the 1st, or load the the 1st video 1st, then append the 2nd
what ever you did, do the opposite order
. That's how you swap the order
I suspect you just made a mistake and picked the wrong video. When I say 1st clip, that's the intro portion. The "2nd clip" refers to the main video -
aaaaaaaaaaaaaaaaa
let me try
edit:
no i don't have any audio ..
when it was at the back i had audioLast edited by DeNeDe; 3rd Jun 2011 at 14:49.
How to make a short animated movie/video clip? Example included.
By UmmAddan in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2009, 10:36 -
Ulead Video Studio 11 - how to add multiple sub and more movie clip
By mic2x in forum SubtitleReplies: 0Last Post: 27th Aug 2008, 13:52 -
Trying to add a small intro clip to a movie file without re-encoding
By solar2504 in forum Video ConversionReplies: 11Last Post: 19th Mar 2008, 10:19 -
By solar2504 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Mar 2008, 02:53
