    Aug 2009
    hi, i have been trying to upload this wmv file that i want to upload to media sites such as facebook, youtube, megaupload,
    or any other media sites,.. the problem ive encountered when ever i try to convert to flash it gets out of sync..
    i tried converting it to mp4, avi, mpeg, etc i could still not upload it properly..
    how can i properly re-encode this wmv file so i can re upload it to flash
    wmv can be stream as its OLD and most of the world use flash and not alot of techy knows how to play wmv file.
    that is why i want it to be in flash.... hope u can help me... heres info on the video
    out of sync video skip to 15:40
    http://www.facebook.com/v/229305373752709
    heres the original file to that^^ the direct link
    http://www.seryeuploads.com/videos/synctest.wmv
    Format : Windows Media
    File size : 93.3 MiB
    Duration : 19mn 59s
    Overall bit rate : 653 Kbps
    Maximum Overall bit rate : 1 233 Kbps
    Movie name : Mula Sa Puso Revival - May 31, 2011
    Encoded date : UTC 2011-05-31 10:43:18.997
    Comment : Processed by freeware version of AsfBin
    Video
    Format : VC-1
    Format profile : MP
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Description of the codec : Windows Media Video 9
    Duration : 19mn 59s
    Bit rate : 580 Kbps
    Width : 512 pixels
    Height : 384 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 fps
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.098
    Stream size : 82.9 MiB (89%)
    Audio
    Format : WMA
    Format version : Version 2
    Codec ID : 161
    Codec ID/Info : Windows Media Audio
    Description of the codec : Windows Media Audio 9.2 - 64 kbps, 44 kHz, stereo (A/V) 2-pass CBR
    Duration : 19mn 59s
    Bit rate mode : Variable
    Bit rate : 64.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Stream size : 9.15 MiB (10%)
    any help appreciated..
  2. when you converted it to various formats, was it in sync before you uploaded to those sites ?
    what programs / converters have you tried so far ?
    Aug 2009
    yes it was sync.. when i uploaded it to facebook thats when i notice it..also evem before uploading the audio gets cut for a couple of seconds..
    Xilisoft Video Converter Ultimate 6
    to mp4 -- audio doesn't get cut for about 10-15 seconds but alittle out of sync about 1/2 second
    TMPGEnc
    output file to MPEG
    it somehow corrects the audio sync but the audio gets cut somewhere in the middle or towards the end for about 10-15 seconds..
    also the video i posted in my original post.. that was out of sync was staight out from wmv file not converted...
    thats about it...
