I use stax 1170 for long time with no problem.but I can't use staxrip1171.I receive an error message about DGINDEXNV and program don't work.program displaye a message that says it can not find DGINDEXNV on my pc.I don't have dgindexnv on ver.1170 but I don't receive this message......
Failed to shell execute command:
DGDecodeNVManual.html
Arguments:
The system cannot find the file specified
System.ComponentModel.Win32Exception: The system cannot find the file specified
at System.Diagnostics.Process.StartWithShellExecuteEx (ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start(String fileName, String arguments)
at StaxRip.GlobalClass.ShellExecute(String cmd, String args) in C:\Users\Frank\Documents\Visual Studio 2010\Projects\StaxMedia\trunk\StaxRip\General\Misc .vb:line 723
What can I do to Solve this issue?
Maybe it's a setting in staxrip where you can choose what dgindex version you should use?
Or continue use staxrip 1170.
Or ask in the doom10 forum, http://doom10.org/index.php?board=22.0
Problem with DGIndexNV - quits without prompt
By PigOnWing in forum Newbie / General discussionsReplies: 0Last Post: 7th Apr 2012, 08:05 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
