The software you are attempting to use does not appear to be designed for an ADVC unit. If it is, then it certainly is not designed very well. I would strongly recommend using something else. If nobody here has heard of it, then it can't be very good capture software.
Some of your theories and ideas on the process are badly in need of more research.
Results 31 to 31 of 31
Codecia DV best settings for capturing Hi-8
By magillagorilla in forum Capturing and VCRReplies: 2Last Post: 2nd Dec 2011, 19:18 -
Panasonic AG-1980 - what settings for capturing?
By justin81 in forum RestorationReplies: 1Last Post: 7th Oct 2010, 18:07 -
Best settings for VHS Rips useing STAXRIP
By contactadam2002 in forum Video ConversionReplies: 3Last Post: 25th Jun 2009, 18:33 -
how to understand what settings to use for capturing
By Fking in forum Newbie / General discussionsReplies: 6Last Post: 15th May 2008, 19:50 -
Best settings for VHS Capture to MPEG2 for archiving...
By VinBob in forum Video ConversionReplies: 12Last Post: 12th Sep 2007, 07:14
