  1. Hi
    I am attempting to use RipBot to shrink MKVs that I have created with MakeMKV. I am running v1.16.5 and the process seems to go smoothly. The MKV is loaded and RipBot presents all the information I am expecting to see. I select my output location and hit the start button. The process works smoothly, no errors are presented. At no stage does my new MKV file get created.
    I am running Windows 7 and RipBot is reporting that all of the require constituent programs are there.
    Any ideas anyone?
    Post the log file. It should be in the ripbot264 log folder.
    Jun 2011
    Sydney
    I seem to have the exact same problem. log file uploaded.
    Any help much appreciated
  4. according to the log the video is here as shown in the log.
    output "E:\temp\RipBot264temp\video.264"
    I would look there, you will most likely find it and have to rename it.
    Good Luck
    If I'd known I was going to live this long, I'd have taken better care of myself.
