Hi,
Using Auto Gordian Knot 2.55 to convert a movie currently in VOB format to AVI but get a VirtualDub Error dialog saying:
Avisynth open failure:
Resize: Source image too small for this resize method. Width=2, Support=3
(C:\Users\My User Name\Documents\DVDFab\MainMovie\Movie Name\VIDEO_TS\agk_tmp\Movie Name_comptest.avs, line 18)
I know I've seen this at least once before and as far as I can recall I managed to find a solution to the problem but can't remember what it was.
Any idea what's wrong or how to solve this?
TIA,
Richard
I found my old post about the very same problem and you're right it's the auto cropping that isn't working as it should for some reason. I tried modifying the auto cropping parameters and by setting one of the values (can't remember the name of the parameter out of my head) to zero I don't get the error but instead the conversion that normally lasts for about 20 minutes only takes about 10 seconds and obviously the result is a failure.
Since this appears to be a Auto GK problem can you or someone else recommend a good free program to convert my VOB files to AVI contained format? I might add that I'm using 64 bit Win 7.//Richard -
I don't use AutoGK but doesn't it show you the AviSynth script it's going to use? Can you post that? There's some secret dialog you can bring up with more controls -- something like Alt+F9. Maybe there's something there.
https://forum.videohelp.com/threads/302354-Why-is-AutoGk-so-much-slower-than-Fairuse-fo...=1#post1851077
Maybe that's what you were referring to.
I would use DgIndex to build an index file of the VOB sequence, an AviSynth script to open the index, then encode with VirtualDub and Xvid. That's essentially what AutoGK does but you have complete control since your doing it all manually.
Other automated programs include Xvid4PSP (which does a lot more than the name implies) and MeGUI.Last edited by jagabo; 2nd Jun 2011 at 06:46.
make use of the 16x16pixel multiple for video frmaer size, because divx requires either 640 either 656 and may allow user
to make a fool out of himself if you feed it a ''wrong'' multpile-not-of16 pixel width video.
If you like to find out all video frame sizes accepted in video codecs,
please use a size--down-area-computer such as
http://www.google.com/url?q=https://forum.videohelp.com/threads/331218/%3Fp%3D2052629&s...dbc6sz6M9SgDYw
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Virtualdub Error
By Hittz in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 08:27 -
VirtualDub error
By WebMaximus in forum Newbie / General discussionsReplies: 22Last Post: 6th Aug 2008, 01:55 -
VirtualDub error
By srikat in forum Newbie / General discussionsReplies: 1Last Post: 24th Aug 2007, 03:40
