Hello.
I have the need to apply fadein and overlay filters to a video. Is it possible to apply 2 filters at once?
I got: ffmpeg -i input.mpg -vf "movie=watermark.png [logo]; [in][logo] overlay=W-w-10:H-h-10 [out]" output.mpg
I'm trying to add "fade=in:0:20", but if I add a new -vf parameter, it will overwrite the preceding one, and if I add: -vf "fade=in:0:20; movie=......" it won't work.
Is this possible to do or do I have to run ffmpeg twice, using one filter at a time?
You have to do it all in one -vf chain but you don't need to run FFmpeg twice.
If you want to fade-in the overlay it should work this way (separate filter commands with commas)...
ffmpeg -i input.mpg -vf "movie=watermark.png, fade=in:0:20 [logo]; [in][logo] overlay=W-w-10:H-h-10 [out]" output.mpg
If you put it after [in], it probably fade in both (didn't try this one)...
ffmpeg -i input.mpg -vf "movie=watermark.png[logo]; [in] fade=in:0:20, [logo] overlay=W-w-10:H-h-10 [out]" output.mpg
Oh, yeah...! commas. I forgot about them.
I tried both commands. The first one won't apply any effect, the second one will apply fadein only to the video, not to the watermark, which is fine.
But then I tried this command:
ffmpeg -i input.mpg -vf "movie=watermark.png [logo]; [in][logo] overlay=W-w-10:H-h-10, fade=in:0:20 [out]" output.mpg
and it applies fadein to both the video and watermark.
Thank you very much for your reply. -
Yes very nice! Now I see there's more logic in that position. First the two inputs, then fade.
Strange that the first example didn't work. Probably because it's a image. I did it where the "movie" command is a video clip so FFmpeg can count the requested number of frames.
applying different filters to different sections in a clip (via avisynth)
By unclescoob in forum RestorationReplies: 28Last Post: 30th Jan 2012, 14:50 -
Importing AVI vids into iMovie after applying Vdub filters: is it possible?
By quantice in forum MacReplies: 17Last Post: 4th Sep 2011, 13:48 -
ffmpeg missing filters :(
By hotnoob in forum Video ConversionReplies: 1Last Post: 26th Aug 2011, 05:48 -
Applying filters to regions of interest (ROIs)
By johnnys5 in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2010, 17:29 -
Photoshop question (applying a transparent layer to multiple psd's)
By Alex_ander in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2007, 09:34
