Hello,
I am capturing video from my TV in mp4 format, with 1080i(60) quality. After I save it to my hard drive, I import it to Adobe Premiere 5.5 as HDV with that quality. I want to upload the video to Youtube in 1080 quality. Here are the things that are happening now:
--If I upload the original video (without exporting), the 1080p quality is perfect.
--If I export the video in Premiere (checking the "match settings" box), the 1080p video has horizontal lines (despite Youtube supposedly having a deinterlacer). However, 720p video looks fine.
--If I go under the "clip" menu and click "Always Deinterlace," then export, the 1080p Youtube video looks alright, but the frame rate is halved (I think). 720 also looks fine here.
--*Also, if I import the video as 1080p, the framerate once exported/uploaded is worse.
It seems to me that if I can upload the original and retain all of the quality, I can export it using Premiere and do the same.
Help anyone?
thanks
Results 1 to 22 of 22
the "framerate" of 60i is 30 "frame" per second. the "60" refers to fields. 2 interlaced fields make up a single frame. when de-interlaced 60i is 30p.
what you have isn't HDV (1440x1080 30i). try a template that matches your input. and export as 1080 30p.--
In the USA, an ATSC or QAM tuner file is probably 1920x1080 60i or 1280x720 60p in MPeg2 TS format. Check with mediainfo.
Set Premiere custom project settings to match the source spec.
For Youtube export set 1920x1080, 29.97 fps, progressive, 1.0 pixel aspect, with h.264 codec. Keep bit rate high ~15,000 Kb/s (reduce if Youtube file size limit is reached).Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
General
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 12.4 MiB
Duration : 11s 345ms
Overall bit rate : 9 142 Kbps
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=64
Codec ID : avc1
Bit rate mode : Variable
Bit rate : 8 983 Kbps
Maximum bit rate : 20.0 Mbps
Width : 720 pixels
Original width : 1 920 pixels
Height : 480 pixels
Original height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 29.970 fps
Minimum frame rate : 29.944 fps
Maximum frame rate : 29.973 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.867
Stream size : 12.1 MiB (98%)
Language : English
those are my video specs. @aedipuss, when i said 1080i 60, that was a typo. I know I have 1080i30.
what should I set the multiplexer for? (between mp4, 3gpp, or none) -
1080 60i, 1080 59.94i, 1080 30i and 1080 29.97i are all the same thing.
What captured that way? Is it a Hauppauge HD-PVR?
Mediainfo says resolution was reduced to 720x480i.Recommends: Kiva.org - Loans that change lives.
I never noticed Mediainfo report "Original" width/height before.
why would you think you're smarter than the mediainfo and everyone here? you've mad a mistake in setting up the capturing program and it is recording in SD. fix your error if you wish to capture HD.--
my computer has well above the specs needed to record in HD, and my TV is set to 1080i. I don't think I'm "smarter" than Mediainfo. After uploading the video and watching it in 720, I compared it to other 720 videos captured by a Hauppauge HD PVR and found that the qualiity was just as good, if not better
I may be a noob at video coding, but I know HD quality.
*Also, if I check the "match sequence" box, Premiere sets the pixel ratio to 1440x1080 (?)Last edited by qatzo; 2nd Jun 2011 at 11:26.
With the HD-PVR all capture encoding is done in hardware. The resolution would be set in the Hauppauge software. The capture file should be evaluated by mediainfo. You can double check with VLC media information or GSpot. If the file is 1920x1080 60i, set Premiere project to 1920x1080 29.97 upper field first. For export encoding for Youtube you can test various settings.
Option 1. h.264 1920x1080 29.97 fps progressive
Option 2. h.264 1280x720 29.97 fps progressive
or send interlace and let them deinterlace it.
1440x1080 is wrong unless that is what you told Hauppauge to capture.Recommends: Kiva.org - Loans that change lives.
Mk I think I've got it worked out...
I'm exporting h.264 1920x1080p 29.97 fps but the frame rate at 1080p (versus 720p) on YouTube always takes a hit... I've just decided to export as 720 because it's almost as good. Thanks for all the help, especially edDV
Best HD settings output from Adobe Premiere for Youtube...
By mhdeaton in forum Video Streaming DownloadingReplies: 4Last Post: 11th Nov 2009, 23:15 -
Encoding for uploading YouTube. Best settings with Adobe Premiere Pro 1.5?
By vid83 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Dec 2008, 19:27 -
YouTube and Adobe Premiere Pro 1.5. What size video? I shoot widescreen.
By vid83 in forum Video Streaming DownloadingReplies: 0Last Post: 16th Jun 2008, 23:32 -
HDV and Adobe Premiere Pro CS 2 or 3
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 5Last Post: 30th Sep 2007, 04:40 -
Adobe Premiere Pro and HDV
By in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 4th Sep 2007, 01:24
thanks
