Results 1 to 10 of 10
    May 2011
    Indonesia
    Three days ago, I'd tried to convert VOB to MKV with FormatFactory 2.60, and in order to reduce the size, I omnly changed the following setting ... the other remains default.
    === Video Encode: AVC (H264)
    === Bitrate: I used only a half original bitrate. If original 5000kbps< , I used 2500<n
    === Encode2pass: YES
    But the result is ... the picture sharpness, was drastically decrease.
    Is there something wrong with my setting?
    Please informed.
    Thanx.
    Currently I used Vista SP2
    It looks okey. But you could try another tool and see how it works. Like Handbrake, VidCoder, Freemake Converter.
    May 2011
    Indonesia
    Will give it a try for HandBrake and H264 encoder
    May 2011
    Indonesia
    I'd give it HandBrake and H264 encoder a try, but the picture's sharpness still drastically decreased.
    And this time ... the decreased is more severe than FactoryFormat I used.
    Why?
    I don't set anything except to:
    * Point the target to be 500MB
    * Confirmed that the sound format to AC3 5.1
    * Activated encode2pass
    Please show me the right setting is.
    Thank you.
  5. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    H.264 at 720x480 and 23.976 fps would likely need a bitrate around 970 kbps.
    970 kbps for video and 448 kps for 5.1 AC3 audio, and the restriction of 500 MB would allow for just 49 minutes of runtime.
    If your movie is longer, then 500 MB just isn't enough.
    May 2011
    Indonesia
    Would you mind for showing me how to calculate that, please?
    .... and the restriction of 500 MB would allow for just 49 minutes of runtime.
    Sorry! My movie is only 24minutes.
  7. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    I used a bitrate calculator inside one of the encoder apps that I frequently use. I don't now about the exact calculation. It is numbers that the app provides, as implemented by its developer.
    If your movie is longer [than 49 minutes], then 500 MB just isn't enough.
    Sorry! My movie is only 24 minutes.
    Then the encoder should have plenty bytes to use on excellent quality. I'm not sure why your encode provides the results you mention in your original post.
    May 2011
    Vietnam
    To be honest, if the video is to be encoded at a low bitrate, it's more likely to exhibit some noticeable artifacts (banding, blocking, etc.), i.e., the image degrades horribly. Try highering the bitrate or encoding at crf>=18.
    Do note that x264 is not so magical that it can downsize a video to half of its original bitrate without losing the image quality.
    May 2011
    Indonesia
    Once I just reduce the original (5000+) bitrate in a half (2400) ... but the result is all the same.
    And I'd tried to convert it into AVI ... all is the same.
    Why?
    May 2011
    Indonesia
    My VOB file, "Magic Flute", which I downloaded from TPB is 720*480 ... the VIDEO_TS folder contains more than 8GB.
    At least ... how big the file will produced, when I convert it to MKV ?
    In order to obtained maximum quality ... at least, how much bit-rate that I should used?
    Yesterday I resize the Video to (600+)x(400+) and targeted 1900MB.
    And the result is ... OK
    But now I wish there's no resize. Please help me ...
    Sorry I used (+) ... cos I forgot the exact number.
    I've tried to used constant quality ... and stated H264 as codec.
    Everything remains default/un-change ... but the result is ... picture sharpness decrease drastically.
    Why? Is the setting that I used is not proper?
