    Mar 2006
    Canada
    Can i do tat?? what software should i use and where can i download them???
    thank you
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hdvd9? What is that? Do you mean avchd? You need to be more specific.
    If you mean h264 video yes you can convert to normal dvd for viewing on a regular dvd player.
    Avstodvd or multiavhcd are two such programs. Format factory is also good.
    Just click on the words with the hyperlinks to get to the download information. They are also found here:
    https://www.videohelp.com/tools
    Just type in the name of the software you want or scroll down the list to find the type of conversion you want to do.
    Mar 2006
    Canada
    nope i really mean HDVD.
    never mind...some1 told me that the quality of HDVD aren't great.
    thank you anyway
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    A Chinese format. Use Google.
    http://www.kiva.org/about
