Hi, I need an advice. I would like to buy authoring software from Xilisoft (Imtoo), it seems to meet my requirements. I picked up two software up to now:
Xilisoft DVD Creator and Xilisoft Video to DVD Converter. However both look very similar. what are the diferences? Which one would you recommend?
Before buying I'd recommend trying out avstodvd and multiavchd to see if they would meet your needs. Both are freeware.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
one is an authoring program and one is a mpeg converter
I'd also recommend using freeware before buying -
Thank you very much both for your replies and recommendation, I' definitely have a look at those freeware. Just one question to Xilisoft I mentioned above: that "Video to DVD Converter" should also be able to create DVD from various types of video files (avi, DivX, Xvid, mov...), shouldn' t it? Just as the DVD creator?
They are both authoring programs. Multiavchd and avstodvd both convert to dvd and author.Originally Posted by zoobieDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Need good BD Authoring software
By faramith in forum Authoring (Blu-ray)Replies: 7Last Post: 13th Sep 2010, 21:17 -
I need new Dvd Authoring software ?
By mrjust in forum Newbie / General discussionsReplies: 10Last Post: 28th Mar 2010, 17:13 -
authoring software.
By Kibble in forum Authoring (DVD)Replies: 1Last Post: 4th Mar 2008, 10:30 -
Best DVD Authoring Software
By mai_hnf in forum Authoring (DVD)Replies: 3Last Post: 30th Sep 2007, 11:25 -
Help on what authoring software to use
By neosatusneu in forum Authoring (DVD)Replies: 5Last Post: 6th Jun 2007, 18:57
