  1. This suddenly started happening two days ago out of nowhere, and it only happens with certain .flv files, other .flv files work fine but some make mpc have a error popup and say it has encountered an error blablala. I can still hear the sound when this happens. I clicked the more info and copied all the info from the log and will provide that so helping me will be as easy as possible.
    Error log or whatever it saved is attatched.
    Thanks in advance for any and all help with this issue
    Info:
    OS: XP 32 Bit
    MPC Version: 1.5.2.3153
    CoreCodec 5.1
    CCCP
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    unsupported flv format/version. In other words, the codec you have installed doesn't support that flv version.
    Or the files are corrupt.
    Google is your Friend
    Nov 2002
    How about a MediaInfo text file from the FLV and a screenshot of MPC-HC and the Internal filters list? I have all my internal filters turned off except for the FLV source filter.
