Okay i cleaned it, i know how to clean the head, but i didnīt know How to get in touch with the head, but i did it more or less.
Here are 2 samples, before and after, though there is no black stripes here, maybe you can see some difference?
Results 871 to 900 of 944
Oh, why not, is something wrong with Lagarith?
People prefer it over UT Video Codec, i myself do most of the time.
Edit:
You can use LAV Filter, it supports Lagarith decoding, i use it as itīs better than the original decoder. -
UT works for my needs better. I won't install LAVF either, this is my work machine and I wan't to keep it clear of clutter. Btw how do you measure what "most of the people" prefer? Also, in absence of video, screenshot will be better than nothing.
A coring filtering is a clipping or cutoff filter. You set it to find pixels that are at or below a specified value, and change their luma/color to the value you want. I used the VirtualDub coring plugin to find all pixels that were RGB 16 or below and change them to RGB 16-16-16. Avisynth's Tweak() has a similar function. I often use it for titles that have noisy black backgrounds. So what you see as "black" is really standard RGB16, not RGB zero. But it looks like zero on tv. Most of the fade-in/fade-up was masked with VirtualDub's FadeFX filter, and some were done in Avisynth. The coring filter was the last filter in the chain after all other adjustments. Some call it the poor man's noise filter, useful in black-and-white video. You have to be careful with it -- it can cause a severely "clipped", ugly look.
With the free VirtualDub Csamp pixel reader, you can play the video in VirtualDub and use Csamp to read the pixel values. You'll see that during some black sections the darkest colors are mostly RGB 15 or 16. The fade at the end was added later with Avisynth (the last fade is really zero black).
I think a great many members here began at that point. I certainly did. And still learning. I've made some hilarious boo-boo's in this forum.
Likewise. This was meant in a relation to the cleaning of video heads which is a delicate process. Sorry for bad choice of words.
I see, i have been using Tweak a bit myself and noticed it has Coring, and i set it to True.. Avisynth's Tweak() has a similar function. I often use it for titles that have noisy black backgrounds
But i donīt really see any improvements in dark areas(Black etc).
and juhok here are samples in UT.
And i donīt really know hopw i can say people prefer Lagarith, itīs just something i think, as Lagarith has better compression, has fast seek times, and everyone here seems to use it, and in many other places.
Only time people have been using UT is when Lagarith is to slow, or has problems. -
This description sounds like a http://avisynth.org/mediawiki/LimiterOriginally Posted by sanlyn
zerowalker: Before and after seem pretty much identical to my bare eyes and also with Avisynth/Histogram(mode="luma"). How about the tape that had the problem? -
Once again, there are no pixels in your video below Y=16 or above Y=235. So there's nothing to crush. The output of Tweak(coring=true) will be exactly the same as the input.
The mathematical operation:
Even if you had pixels with Y<16 or Y>235 you wouldn't see any difference when viewed on your monitor (unless your video card's video proc amp is maladjusted) because the graphics card will do the crushing when it converts to RGB. The same with VirtualDub. The same should be true for Televisions but sometimes they mess up with Y<16 or Y>235.Code:if Y is less than 16 make Y equal 16 if Y is greater than 235 make Y equal 235 otherwise, don't change Y
OOPS!
Anyway, there are dozens of how-to head cleaning videos and articles online. My first cleaning adventure came from a book on VCR repair. I was scared to death. I followed the book (it's a gtood thing the book had pictures!), got the right tools and cleaner, and went to it. Succeeded the first time!Last edited by sanlyn; 26th Mar 2014 at 02:50.
Yeah well i did my first on my earlier VCR and it went fine i guess (it didnīt break
), and the Camcorder still works.
I did as recommended and from a youtube guide, dry and/or 99% alcohol dipped papper.
and hold it against the drum and rotate it while holding it still.
Seems to work atleast, havenīt fixed any real problem for me yet though, but havenīt made any either
Oh and a question, what is a good way to clean different parts?
Letīs say itīs day from 1 to frame 1240, then itīs dark from 1241 to 6000.
Is it the normal Trim() that is appropriate? -
Be careful with using paper for everyday cleaning. The paper is abrasive, it'll work, but it shortens the lifespan of the heads. Chamois tips are more gentle solution.
I see a lot of people use paper, but not cheap bargain copy paper (it's dusty), and certainly not that fancy woven "rag content" for resume's and never use lens cleaning paper (it has loose fibers). But I'm with juhok here, the chamois tips are the safest. They're not expensive, they last a long time, and you can use both sides of the tips. IF you want to get even cheaper, you can use cotton swabs on the plastic and metal rollers, tape guides and posts, and the audio and erase heads. Don't try to clean rubber belts, it's too easy to pull them out of shape or out of position. Some people clean the large black capstan roller; I just wipe them with a dry chamois or swab, as some chemicals can affect rubber parts. Don't wipe away any lubricant; they are there for a purpose (to lubricate moving parts, of course). Tape doesn't touch the lubricated areas anyway.
A drawing of the parts usually found in the tape path. The number of smaller parts and their placement might differ.
Okay can say that the Black Stripes are still there, so can pretty much conclude that itīs the Tape, as they always appear at the same places i think.
But the Chamois tips, can someone please link me where to buy it?
I donīt think i have seen it.
And yes we have paper with Rough surface (which i didnīt use, as well it didnīt seem safe), and paper with that Blank Clean surface, which i did use. -
Okay did some more tests, and can just say that i must change my capture card truly now, cause the White Crush is to "AGC", i thought it would be stuch at a place and then all i fine, but it seems like places that are bright become "dark", even though white crush isnīt needed there.
And it isnīt fast enough to be discreet, so it will look bad if i speed it up, and it will be to dark everywhere though still.
as ATI Wonder doesnīt seem like my choice, i am looking towards: Blackmagic Design Intensity Pro
Itīs the one you are using juhok, right?
Can you tell me more precisely wht it can capture and what it canīt?
Cause if it can capture HDMI, Component and all that with atleast 1080i at 60 (that will mean 30 fps but fully interlaced), i will be happy, though 1080i/p 60 fps would be nice)
EDIT:
This was not the one you had, i read it up*;PLast edited by zerowalker; 1st Sep 2012 at 00:55.
Yeah i know, but there are ways to bypass that
Though i donīt know if there is a driver tweak for that;S
But i checked the specs, it seems to support everything up to 1080p 30 / 1080i 60.
But what i canīt get specs on are the ADC, is it 10bit or 12 etc.
And what are the SNR, does it support the entire dynamic range that analogue stuff has to offer etc. -
After reading around it seems like this card as the same problems my previous card i bought had.
With that i mean, it will drop frames and audio thanks to bad sync, so i must have a TBC.
And i donīt really want to buy a card, then a TBC, thatīs just to much:S -
Blackmagic Design cards, like BT878, need Frame Sync/TBC inbetween unstable source and capture card. I'm surprised if your card works without one.
I don't know what you mean by analog dynamic range. It will capture according to SD specs. 10 or 12 or 14 bits have nothing to do with it being able to capture "outside of the specs". Your source = VHS/Video8 - doesn't have "everything that analogue has to offer". Dimishing returns. -
Well i donīt need a TBC, i donīt think ATI AIW does either (may be wrong).
And with Dynamic Range, i meant the Audio, like SNR etc.
I know what VHS doesnīt have more than 6 bits, but you still want more i think, but 10 bit is enough, i think my card has 9 bit, and that should have enough space anyway.
But i canīt really afford buying a TBC, they cost a lot right?
And you want to keep the Chain of devices as short as possible. -
If you think audio you don't need 120dB of SNR in your AD if you're recording material that has 30dB SNR.
Shortest signal path doesn't guarantee best results. It's more complicated than that. Dropped frames and/or desync or other problems are definetely not worth slight increase in PQ.
Here's something about consumer TBCs and prices http://www.digitalfaq.com/forum/video-restore/2251-tbc-time-base.html -
I know that you only need a bit more than the original SNR for it to be "identical", but if i remember right, Hifi has some very high SNR, like 70db or something?If you think audio you don't need 120dB of SNR in your AD if you're recording material that has 30dB SNR.
Itīs on par with CD Audio.
Very true, as long as it doesnīt add some bad patterns/noise etc.Shortest signal path doesn't guarantee best results. It's more complicated than that. Dropped frames and/or desync or other problems are definetely not worth slight increase in PQ.
But the cost of those TBC are about 3000kr without shipment for me (i live in sweden).
And thatīs a very high price, when i need to add a new capture card to it aswell.
Does anyone know if the ATI on PCI need a TBC or not? -
I was trying to make an analogy to VHS and 12-bit sampling.
Average price on eBay for used TBC-1000 is about $200 USD, with shipping and taxes it still falls far from 3000 SEK. AVT from UK is 165 http://www.markertek.co.uk/Catalog/Time-Base-Correctors-Frame-Synchronizers/AVT-8710 - no customs duties to Sweden from UK. There are plenty of pretty cheap options. I do not endorse TBC-1000 or AVT-8710 over each other or anything else, I only wanted to make a case for the cheaper price. -
Oh okay, well good that we understand what we meant with the Bits and SNR
But about the TBC, does the TBC-1000 work good?
As i have read that some doesnīt have True S-video and makes that Crosstalk pattern (Search for S-video Artifacts).
I only want the TBC to to what itīs supposed to do, nothing more nothing less.
I donīt care about if it has 10x RCA distribution and stuff, i just want it to Stabilize the Frame Sync.
And i read that this TBC you linked has Sharpness, AGC etc, isnīt that what i donīt want to have?
Even more adjustments i mean? -
Well enough for it's (used) price.
Not true. It supports S-video. There can be broken ones around like with everything.
You cannot pick and choose. In this price class there are these few devices. There are all kinds of exotic high-risk options which may or may not work and may or may not cost less.
I've never used AVT. I suppose you can select if you want it enabled or not. Download and read the manuals so you know better what they will and will not do.
Help me out with some questions about converting VHS to DVD?
By starheavenheat in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2009, 23:22 -
45
By inherindian in forum Newbie / General discussionsReplies: 7Last Post: 4th Mar 2009, 20:26 -
Converting Cartoons to Xvid
By CartoonManic in forum Video ConversionReplies: 16Last Post: 15th Jun 2008, 16:31 -
3 questions about VHS > DVD
By Salva Veritate in forum Capturing and VCRReplies: 13Last Post: 26th Jan 2008, 14:05 -
A few questions regarding capturing processing and archival of home VHS vid
By ido22 in forum Capturing and VCRReplies: 2Last Post: 20th Aug 2007, 02:37
