Hello. I have a movie in mkv format that i want to edit. But the key frames or intra frames (scene-breaks) do not appear between scenes as they should. No matter what format i edit it in or convert it to, or what codec i encode it with, the scene breaks are always in the same uniform 10-15 second points instead of at scene changes like most other movies im used to editing with. Is it the source file's fault or is there any way i can fix it? Any help is appreciated. Below are the source files specs.
Format : Matroska
File size : 5.67 GiB
Duration : 2h 3mn
Overall bit rate : 6 547 Kbps
Encoded date : UTC 2011-05-26 08:16:22
Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 12 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 3mn
Bit rate : 4 906 Kbps
Nominal bit rate : 5 041 Kbps
Width : 1 280 pixels
Height : 542 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.295
Stream size : 4.24 GiB (75%)
Title : Notting.Hill.1999.BluRay.720p.DTS.2Audio.x264-CHD
Writing library : x264 core 104 r1703 cd21d05
Encoding settings : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.05:0.10 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=5041 / ratetol=1.0 / qcomp=0.70 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=1:0.70 / nal_hrd=none
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 3mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 1.31 GiB (23%)
Title : DTS-HDMA core 5.1CH 1509kbps
Is there anything that can change the key frame placement in a file?
Well, key frames are where the encoder put them, it doesn't necessarily is between two scenes.
If what you want to do is split a big file into smaller chunks, SolveigMM Avi trimmer + MKV or Mkvmerge are your best bets.
Avidemux: The beginning frame is not a key frame. Please move the A marker
By devilcoelhodog in forum EditingReplies: 13Last Post: 8th Jun 2015, 12:38 -
Xvid4PSP key frame interval setting?
By x2x3x2 in forum Video ConversionReplies: 0Last Post: 30th Dec 2010, 23:19 -
How to cut xvid avi by a non-key frame
By Kirill in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2010, 06:52 -
configure XVID so virtualdub key I-frame's is able to go 1,2,3,4,...?
By Ghtpua in forum EditingReplies: 0Last Post: 21st Oct 2007, 14:05 -
Virtualdub: the key frame displayed is off
By cheerful in forum Newbie / General discussionsReplies: 11Last Post: 19th Jun 2007, 12:28
