My former PC, Sony's Digital Living Center, has been replaced in my home. This concept included two components; a PC and a 200-disc carousel that had burning abilities which I never used. I would like to keep the carousel feature, but the only cabling connection option is the IEEE1394, which seems to be obsolete these days since USB 2.0 and 3.0 were born.
Does anyone know if there is a cable that will allow me to connect the IEEE port from the carousel to a USB port on my new PC? Or do I have to junk the carousel as well?
No such thing that works for video transfer.
Instead add an IEEE-1394 card or cardbus to your new computer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815166018&cm_re=IEEE-1394-_-15-1...-018-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16815158006&cm_re=IEEE-1394-_-15-1...-006-_-ProductRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
OK, I had to ask. I bought one of those slimlines which I'm sure won't support any additional cards. I don't get into the insides of PCs anyways as those things have a mind of their own.
I appreciate you taking the time to answer my question though. MUCH MUCH appreciation.
Sony camcorder HDV tape to iMac with iLink ieee1394 cable
By Rossbo in forum MacReplies: 6Last Post: 1st Feb 2010, 19:46 -
miniDV player with IEEE1394 Firewire OUT (?)
By jimcornetet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 30th Dec 2007, 23:34 -
Transfer data code while dubbing miniDV -> DVD+R using IEEE1394/iLink
By alokeprasad in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2007, 08:25
