I'm trying to convert a piece of xvid video I have to h264 in order to be able to append it to another piece of h264 video I have.
I have tried to do it using virtualdubmod and I did get a resulting h264 video. However, when I append them together with mkvmerger, the program gives me an error about byte discrepancy. I take it the encoding options I used to encode that h264 were different from the piece I'm trying to append to. I tried to override that by using avimux (inside an mkv container) and while the resulting video plays, once the junction point comes the video shows a bunch of artifacts.
What do I need to do to be able to encode that xvid to an h264 that will be compatible to append? Any tools that could read the encoding options used for a piece of h264 so I can encode the 2nd piece accordingly? And can I change all those options in the h264 used by Virtualdubmod or do I need a new h264 encoder?
Maybe easiest to just reconvert both with exact same settings.
I know that'd be the easiest way, but I'm completely opposed to a complete reencode because no matter how small I would lose some quality in the process and the thing I'm trying to append is only like 1% of the total video length. So I'd have to sacrifice a little quality on the remaining 99% and I'm really trying to avoid that.
1) What parameter(s) would cause two h264 streams to not be able to be appended to each other?
2) How can I identify which parameters in question are the ones that are different in my case?
3) Can I modify those encoding parameters with the h264 codec that is available for Virtualdubmod or do I have to get a new encoder? -
Convert both to a dvd format to be able to pass over it. If you prefer sharing use quality brand blue-rays
What form of h264 will VideoRedo h264 tvsuite accept?
By Asterra in forum Video ConversionReplies: 4Last Post: 12th Apr 2012, 13:22 -
Cropping fails on H264 to H264 encodes
By gtwibell in forum ffmpegX general discussionReplies: 1Last Post: 24th Feb 2009, 12:34 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 19:06 -
problems with an .h264 mvk converting to DVD with .srt subs
By jbeaman in forum ffmpegX general discussionReplies: 1Last Post: 2nd Aug 2008, 09:56 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 01:20
