I have a ton of footage that I've been capturing over the past few weeks. Most of the time, I'll have 30 minutes-worth of footage but will only need 5 minutes from the whole thing. Is there any way to pull the footage that I need and discard the rest without any form of re-compression? Some sort of direct-stream copy option for a particular section that won't descync the audio? I am capturing using a BMD Intensity Shuttle and AVI Motion JPEG compression.
yes - use virtualdub and use direct stream copy. Just cut and it saves it as is. I've never worked with mjpeg video but I'm sure if the regular vdub doesn't immediately see it virtualdubmod will. Or open with the directshowsource avisynth template to read the file.
AVI Motion JPEG to x264 in Matroska MKV container
By Michielvsb in forum Video ConversionReplies: 2Last Post: 20th Apr 2011, 03:12 -
Best Conversion from AVI (Motion JPEG) to MP4
By cademichaels in forum Video ConversionReplies: 3Last Post: 12th Apr 2010, 21:34 -
How to convert to AVI Motion JPEG?
By BobAchgill in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2008, 16:59 -
Which of these TV-cards capture analog to AVI, using Huffyuv or M-JPEG,...
By dOdGE dIZ in forum Capturing and VCRReplies: 15Last Post: 9th Mar 2008, 08:01 -
How do I convert Motion JPEG to MPEG-1?
By TheEvilHammer in forum Video ConversionReplies: 6Last Post: 18th Oct 2007, 18:58
