Hi!
I'm looking for some software to do rip 3D-BD's to individual MKV files.
I know 3DBD Buster, DVDFab, and SSIFSucka!, but all of these programs have some sort of problem. Anyone know of other software or way to rip 3DBD?
I know it is possible to rip both files (left and right) from the SSIF files of a 3DBD using HdBrStreamExtractor, however this program create two H264/AVC files. What program can I use to convert this files to MKV with a bitrate determined by me?
Only one more question, the SSIFSucka! still at beta3 version?
What problems are you having?
I ripped my bluray 3ds with anydvdhd. Then I used dvdfab 3d bluray ripper to make a side by side mkv out of it. From there I used a avisynth template put together with the help of jagabo and cornucopia to make an anaglyph 3d file that I can play and use paper glasses with.
I paid for the dvdfab3d bluray software as well as anydvdhd. They are seperate and anydvdhd has to be completely exited for dvdfab3d bluray ripper to work but that is not a problem since its already ripped to the harddrive before I start the side by side conversion.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
SSIFSucka! is garbage.
SSIFSucka! spyware.
SSIFSucka! virus.
SSIFSucka! trojan.
....just in case.
I'm always having conversion errors ... and often are different. I need MKV files to use with active glasses, and I wanted to avoid conversions on conversions to avoid losing image quality ...
I sometimes have used SSIFSucka!, and I never had problems with trojans, viruses, or whatever! Or at least my antivirus does not complain ... what site did you download this program? -
3dbdbuster site no longer exists, maybe because program went payware.
Alternatives for download of old versions?-- Jumpjack --
Ripping blu-ray
By freeman3030 in forum MacReplies: 9Last Post: 12th May 2012, 09:27 -
Best blu ray ripping software for Mac?
By FuzzyReets in forum Blu-ray RippingReplies: 5Last Post: 5th Sep 2011, 22:53 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
What 's the best hardware and software for ripping blu-ray movies?
By HartsVideo in forum Blu-ray RippingReplies: 70Last Post: 6th Nov 2010, 17:02 -
ripping blu ray software without image
By ShinjiIkari1990 in forum Blu-ray RippingReplies: 1Last Post: 12th Jun 2009, 23:34
