Results 1 to 13 of 13
  1. I didn't really know where to put this cause I don't know what the source of the problem is but here goes.
    When playing my homemade DVD in my DVD-player, the video/audio is choppy whenever I jump to a chapter. But if I fastforward only for a second it's fine after. And playing it from the start is completely fine. Playing it on my 2 different computers: no problems.
    Tried 3 dvds with different speeds, all with the same result. Could this be a problem with my player? Or problem with authoring/encoding? It is a PAL dvd authored in Encore and the main timeline is encoded in tmpgenc. This is a DVD that I'm going to pass out and I don't want it to be like this on the other peoples player, if it was for just me I wouldnt care.
    My dvd-player is a Samsung BD-C5500.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Run one of the VOB files through MediaInfo or GSpot and post the results....without that everything would be a guess.
  3. Originally Posted by hech54 View Post
    Do you mean the mpeg-file?
  4. He means the VOB files. DVD video has the extension VOB, as opposed to the IFO and BUP files DVDs also have.
  5. Originally Posted by manono View Post
    Ah of course, on the DVD. Sorry I'm tired
    Ran one of them in Mediainfo on advanced mode, tell me if something is missing:
    General
    Count : 277
    Count of stream of this kind : 1
    Kind of stream : General
    Stream identifier : 0
    Inform : MPEG-PS: 1 024 MiB, 22mn 51s
    Count of video streams : 1
    Count of audio streams : 1
    Count of menu streams : 1
    Video_Format_List : MPEG Video
    Video_Format_WithHint_List : MPEG Video
    Codecs Video : MPEG-2 Video
    Audio_Format_List : AC-3
    Audio_Format_WithHint_List : AC-3
    Audio codecs : AC3
    Menu_Format_List : DVD-Video
    Menu_Format_WithHint_List : DVD-Video
    Menu codecs : DVD-Video
    Complete name : E:\VIDEO_TS\VTS_01_1.VOB
    Folder name : E:\VIDEO_TS
    File name : VTS_01_1
    File extension : vob
    Format : MPEG-PS
    Format : MPEG-PS
    Format/Extensions usually used : mpeg mpg m2p vob pss
    Commercial name : MPEG-PS
    Internet media type : video/MP2P
    Codec : MPEG-PS
    Codec : MPEG-PS
    Codec/Extensions usually used : mpeg mpg m2p vob pss
    File size : 1073709056
    File size : 1 024 MiB
    File size : 1 024.0 MiB
    Duration : 1371480
    Duration : 22mn 51s
    Duration : 22mn 51s 480ms
    Duration : 22mn 51s
    Duration : 00:22:51.480
    Overall bit rate : 6263067
    Overall bit rate : 6 263 Kbps
    Stream size : 21369852
    Stream size : 20.4 MiB (2%)
    Stream size : 20 MiB
    Stream size : 20.38 MiB
    Proportion of this stream : 0.01990
    File creation date : UTC 2011-05-29 23:11:14.000
    File creation date (local) : 2011-05-30 01:11:14.000
    File last modification date : UTC 2011-05-29 23:11:14.000
    File last modification date (loc : 2011-05-30 01:11:14.000
    Video
    Count : 194
    Kind of stream : Video
    Inform : 5 946 Kbps (8 000 Kbps), 720*576 (16:9), at 25.000 fps, MPEG Video (PAL) (Version 2) (Main@Main) (BVOP)
    Format : MPEG Video
    Commercial name : MPEG-2 Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings : BVOP
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Internet media type : video/MPV
    Codec : MPEG-2V
    Codec : MPEG-2 Video
    Codec/Family : MPEG-V
    Codec profile : Main@Main
    Codec settings, Matrix : Default
    Duration : 1371480
    Duration : 22mn 51s
    Duration : 22mn 51s
    Bit rate mode : VBR
    Bit rate mode : Variable
    Bit rate : 5946432
    Bit rate : 5 946 Kbps
    Nominal bit rate : 8000000
    Nominal bit rate : 8 000 Kbps
    Width : 720
    Width : 720 pixels
    Height : 576
    Height : 576 pixels
    Pixel aspect ratio : 1.422
    Display aspect ratio : 1.778
    Display aspect ratio : 16:9
    Frame rate : 25.000
    Frame rate : 25.000 fps
    Frame count : 34287
    Standard : PAL
    Resolution : 8
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : TFF
    Scan order : Top Field First
    Interlacement : TFF
    Interlacement : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.574
    Delay : 60.000
    Delay : 60ms
    Delay : 60ms
    Delay : 60ms
    Delay : 00:00:00.060
    Delay, origin : Container
    Delay_Original : 0
    Delay_Original : 00:00:00.000
    Delay_Original_Settings : drop_frame_flag=0 / closed_gop=1 / broken_link=0
    Delay_Original_Source : Stream
    Stream size : 1019426564
    Stream size : 972 MiB (95%)
    Stream size : 972.2 MiB
    Proportion of this stream : 0.94944
    Buffer size : 229376
    intra_dc_precision : 9
    Audio
    Count : 177
    Kind of stream : Audio
    Inform : 192 Kbps, 48.0 KHz, 16 bits, 2 channels, AC-3 (DVD-Video)
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Commercial name : AC-3
    Muxing mode : DVD-Video
    Codec : AC3
    Codec : AC3
    Duration : 1371360
    Duration : 22mn 51s
    Duration : 22mn 51s 360ms
    Duration : 22mn 51s
    Duration : 00:22:51.360
    Bit rate mode : CBR
    Bit rate mode : Constant
    Bit rate : 192000
    Bit rate : 192 Kbps
    Channel(s) : 2
    Channel(s) : 2 channels
    Channel positions : 2/0/0
    Sampling rate : 48000
    Sampling rate : 48.0 KHz
    Samples count : 65825280
    Frame count : 42855
    Resolution : 16
    Resolution : 16 bits
    Bit depth : 16
    Bit depth : 16 bits
    Delay : 60.000
    Delay : 60ms
    Delay : 60ms
    Delay : 60ms
    Delay relative to video : 0
    Video0 delay : 0
    Stream size : 32912640
    Stream size : 31.4 MiB (3%)
    Stream size : 31 MiB
    Stream size : 31.39 MiB
    Proportion of this stream : 0.03065
    dsurmod : 0
    dialnorm : -31
    dialnorm/String : -31 dB
    compr : -11.02
    compr/String : -11.02 dB
    bsid : 4
    dialnorm_Average : -31
    dialnorm_Average/String : -31 dB
    dialnorm_Minimum : -31
    dialnorm_Minimum/String : -31 dB
    dialnorm_Maximum : -31
    dialnorm_Maximum/String : -31 dB
    dialnorm_Count : 2
    compr_Average : -11.02
    compr_Average/String : -11.02 dB
    compr_Minimum : -11.02
    compr_Minimum/String : -11.02 dB
    compr_Maximum : -11.02
    compr_Maximum/String : -11.02 dB
    compr_Count : 2
    Menu
    Count : 71
    Kind of stream : Menu
    Format : DVD-Video
    Commercial name : DVD-Video
    Codec : DVD-Video
    Codec : DVD-Video
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    That's PAL format alright....bt why did you "announce" that it is PAL format? Are you in a PAL country?
  7. Originally Posted by hech54 View Post
    Yes i'm in a PAL country. Maybe I should of added that. Was just trying to add as much info as possible to the op.
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    That's a strange one. Nothing looks out of the ordinary to me. I know nothing about Encore but you say you encoded with TMPGenc? What did you author the DVD with? I know new versions of TMPGEnc "do it all" now....so you probably authored with TMPGEnc as well....just trying to narrow it down a bit.
    May 2001
    The username "euroboy" wasn't a clue for you? Also, Encore is the authoring program.
    euroboy, how did you map the chapters? Also, how big are your GOPs?
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  10. Yes Encore was the authoring program.
    I'm at a friends house right now and I tried a disc on his PS3 and it worked so it might be my dvd-player, could upscaling do this?
    GOP sorry I don't know right now, I never touched those numbers, I remember something like 5 and 13 or something maybe(?)
    I imported my tmpgenc encoded mpeg (first edited in premiere) into Encore and created a timeline and on that timeline I added chapters, if thats what you mean.
  11. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Wow...that gives the impression of immense intelligence.....can I hang with you?
    May 2001
    Well, maybe... but you'll have to get a note from your mommy saying that it is okay with her.
  13. lol drama!
    Anyway I fixed it. I think there was some problem with the mpeg2, too many conversions. I didn't know frameserver existed for cs5 so when I found out I reencoded the premiere-project with frameserve directly to procoder 3 and used that mpeg in encore instead. And it worked. Took some extra hourse though :/
    Thanks for the help though!
