Results 1 to 13 of 13
    Apr 2007
    Greece
    I use Sony vegas pro 10d
    I have a video during 2 minute. Iwant to change a color film to black and white after 20 first seconds and change again to colour after 25 seconds and again to black and white until the end of the film
    How can to do this please??
    thanks
    Apr 2004
    Miskatonic U
    Add a HSL Adjust Event FX to the clip, then key frame the saturation levels over time.
    Read my blog here.
    Apr 2007
    Greece
    thanks!!
  4. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Hahaha, or add a B/W filter and keyframe that one.
    Apr 2007
    Greece
    Another question please!!!
    I use SONY Vegas Pro 10d
    I have 3 photos and i want to input in the video (at the begining) witch i have.
    These 3 photos can view (in video) for 5 seconds each one.(one after one).
    In witch way can i do this??
    p.s Is there an efect for this?? For example... to show these fotos to animate like waves ( because the video shows the sea!!!)
    Thanks again
  6. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    This is a great question that showcases how to translate YOUR fresh idea into reality in Vegas.
    There is an efx called "Sony Wave". And you will want to animate it, no?
    To animate it, turn on the keyframes, and create your start/stop region, then loop it.
    If you want to blend(composite) the fotos with the video, put the fotos on their own track and turn on the composite envelope.
    Depending on the material, you can Dodge, Burn, Add, Overlay the fotos to make an interesting effect.
    You can use track motion to make the fotos rise out of the sea, and fly away with the wind, while they flap like a magic carpet.
    Apr 2007
    Greece
    "You can use track motion to make the fotos rise out of the sea, and fly away with the wind, while they flap like a magic carpet."
    Yes!!!! This is exacly i want to do!!
    At first about 30 seconds video (shows the sea with waves)..then the first photo(fly away with wind)...then the sea with waves (again)...then the second photo ..then the sea with waves e.t.c.
    I want to show something like memories witch "back" again and again.
    Can you repeat the steps witch i do inside the Vegas please ??? ( I have the Sony vegas version 10d)
    Thanks again Mr Stedanko !!
  8. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    OK, later today.
    I think since you have Vegas 10 Pro right? That I can make a project file for you, then you can replace with your own media.
    EDIT: Take a look at this clip and give me some details about what you want. http://youtu.be/eOpmRx2ckGc?hd=1
    Apr 2007
    Greece
    "I think since you have Vegas 10 Pro right"
    Yes Ihave Vegas Pro version 10d (the last)
    Thanks Again !!!!!!!!!
    p.s.
    Now here is about midnight (Greece) ....no problem ...tomorow!!!!
    Apr 2007
    Greece
    Yes something like that!!
  11. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    OK, here's the VEG file.
    There's a lot more you can do, this is a rough outline, and you will see what tools were used.
    When you open this file, it will pop a dialog, just "ignore all missing files". Then right click on each event, and use "replace".
    Apr 2007
    Greece
    thanks a lot !!
    I am grateful to
