Hi all,
Since I frequently work with both audio and video I've run into a problem that I've dealt with many times but would like to know what the general consensus is about it.
When using lossless video, you're bound to run into an interlaced frame. Ie., part of the previous frame shows and part of the next frame shows...
Now, when doing audio work, what's the best way to handle such frames? For instance, if one shot shows a nail being hammered in the Center channel, then the next shot shows it off-screen to the Front Left, how do you know where to begin the audio pan?
I'm hoping you understand what I mean.
Thanks for your help![]()
I hardly think it matters. But if you want perfection: the two fields in an interlaced frame are to be viewed sequentially, so the sound should change half way through the frame.
Editing with 2 different Frames Per Second (Canon 7D)
By Relevent Media in forum Newbie / General discussionsReplies: 8Last Post: 22nd Jul 2010, 21:33 -
Why are there spurious? frames in my interlaced PAL capture - sample clip
By BigMick in forum Capturing and VCRReplies: 5Last Post: 11th Jan 2010, 07:29 -
editing frames of of a clip
By JerryB in forum EditingReplies: 6Last Post: 25th Aug 2009, 22:00 -
Editing certain frames in VOB MPEG?
By Information in forum EditingReplies: 2Last Post: 18th May 2009, 20:14 -
Editing / Deleting Sound & Frames
By staminet in forum EditingReplies: 0Last Post: 10th May 2007, 12:03
