Is there any way to capture the trailers that are streamed on the Itunes store? There are a TON of them from older movies that aren't available anywhere else and I'd LOVE to capture them. Anyone have any ideas?
Results 1 to 25 of 25
Hi
Do you mean the trailers that are on website __http://trailers.apple.com/ ? -
Unless they have a "download" option for the trailers I'm afraid it is. - edit - even then they will almost certainly be encrypted.
Are you sure there aren't any trailers for these movies online elsewhere that might be able to be downloaded via other means?Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
@digitalfreaknyc - I'd try looking a little harder next time-
Both Ferris Bueller and backdraft have trailers on imdb.com. I'm sure a good deal more are on there as well.
Whether or not imdb.com has implemented the newer rmpte protocols that make streamtransport useless I don't know. But I believe it is rtmpdump that works. There is a huge thread on the forum for downloading video off websites.
Keep looking and I'm sure you'll find all your trailers online somewhere.
But you may still need to do screen recording for some of them if you can't find alternate sources for them - or have trouble downloading them from a website.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
CooJah with the option "Sniff All Network Apps" enabled finds the links but the files seem to be drm protected and only play on quicktime
http://a424.v.phobos.apple.com/us/r1000/012/Video/81/3c/d6/mzm.wnjfsxwz..640x348.h264lc.D2.p.m4v -
No, I haven't got an iTunes account.
I used k's link with Linux like this:-
Maybe WinWget will do the same job with Windows.Code:wget http://a424.v.phobos.apple.com/us/r1000/012/Video/81/3c/d6/mzm.wnjfsxwz..640x348.h264lc.D2.p.m4v
MediaInfo shows that the video is encrypted.
mPlayer won't play it.
But VLC v1.1.9 plays it OK.
Complete name : mzm.wnjfsxwz..640x348.h264lc.D2.p.m4v
Format : MPEG-4
Codec ID : M4V
File size : 35.8 MiB
Duration : 3mn 1s
Overall bit rate : 1 652 Kbps
Encoded date : UTC 2008-07-15 04:30:07
Tagged date : UTC 2008-07-15 04:30:08
Video
Format : AVC
Format profile : Baseline@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : drmi
Duration : 3mn 1s
Bit rate mode : Variable
Bit rate : 1 535 Kbps
Maximum bit rate : 64 bps
Width : 640 pixels
Height : 348 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.287
Stream size : 33.2 MiB (93%)
Language : English
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 3mn 1s
Bit rate mode : Constant
Bit rate : 113 Kbps
Nominal bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 2.44 MiB (7%)
Language : English
Encryption : iTunesLast edited by bat999; 30th May 2011 at 19:14.
VideoHelp's rules have changed since this thread began. If you mean that you want to save HD or FHD versions of trailers and/or full videos in unencrypted form rather than the encrypted file downloads that iTunes supports, that sort of discussion is forbidden under the current AUP.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Question about TV show download from Itunes
By jimdagys in forum Newbie / General discussionsReplies: 8Last Post: 31st Oct 2008, 00:21 -
How To Record , Capture, Or Download This Flash Video From Brightcove.com
By hypnoticpimp in forum Video Streaming DownloadingReplies: 1Last Post: 17th Jun 2008, 13:13 -
The Vital Message - General Fiction, download ebooks, free download, The
By spacek77u in forum DVD RippingReplies: 1Last Post: 14th May 2007, 01:29
