Using AVCHD for first time, not made it very far as I get error 0x0401 when converting video.
Google search did not provide the answer!
Video is HD MP4 file from samsung s10 camcorder (1920 x 1080i 50 fps H264).
Below is the log file from AVCHD, in addition I have uploaded a test file (2 seconds in length (5mb in size) to http://time2innov8.co.uk/files/avchdtest.mp4 in case anyone wants to try it.
time2innov8
20:08:28 - --------Adding item---------
20:08:29 - Source: K:\HD Samsung\AVCHD Test.MP4
20:08:29 - Source: Video: 1. 00:00:02 (1920x1080i, 50.000fps, H264)
20:08:29 - Source: Audio: 2. English (2ch, AAC - Kbps)
20:08:29 - Target: Video: 1. 00:00:02 (1920x1080i, 25fps, H264)
20:08:29 - Target: Audio: 2. eng (AC3 192 Kbps)
20:08:29 - --------Item added---------
20:09:12 - --------Conversion started---------
20:09:13 - Creating META file: MUXOPT --no-pcr-on-video-pid --new-audio-pes --demux --vbr --vbv-len=500
20:09:13 - Creating META file: A_AAC, "K:\HD Samsung\AVCHD Test.MP4", track=2
20:09:13 - Demuxing with TsMuxer: "H:\Program Files\AVCHDCoder\Tools\tsMuxeR_1.10.6\tsMuxeR.exe" "K:\temp\test 1 - item 1\test 12.META" "K:\temp\test 1 - item 1\"
20:09:15 - Converting aac to wav with faad: "H:\Program Files\AVCHDCoder\Tools\FAAD\faad.exe" -o "K:\temp\test 1 - item 1\test 1 1.wav" "K:\temp\test 1 - item 1\test 1 1.aac"
20:09:17 - Converting file to ac3 with eac3to: "H:\Program Files\AVCHDCoder\Tools\eac3to\eac3to.exe" "K:\temp\test 1 - item 1\test 1 1.wav" "K:\temp\test 1 - item 1\test 1 1.ac3" -192 -progressnumbers
20:09:19 - Calculated bitrate: 17808
20:09:19 - Total Subtitles size: -1.0
20:09:19 - Creating AVS file: DirectShowsource("K:\HD Samsung\AVCHD Test.MP4",fps=50.000,audio=false).ConvertToYV12(). ChangeFPS(25).addborders(0,0,0,0)
20:09:19 - Encoding started in 32 bit.
20:09:19 - Encoding Pass 1: "H:\Program Files\AVCHDCoder\Tools\X264\32bit\x264.exe" --pass 1 --bitrate 17808 --weightp 0 --bframes 3 --nal-hrd vbr --vbv-maxrate 18000 --vbv-bufsize 18000 --level 4.1 --keyint 25 --b-pyramid strict --slices 4 --aud --bluray-compat --open-gop --stats "K:\temp\test 1 - item 1\test 1.stats" --fps 25 --force-cfr --sar 1:1 --direct auto --tff --output NUL "K:\temp\test 1 - item 1\test 1.avs"
20:09:23 - Converting video pass 1: Errorcode: 0x0401,Error occured when converting video
Results 1 to 11 of 11
When you installed avchdcoder did you also install avisynth?
Can you play the mp4 in windows media player? -
IIRC, AVCHDCoder can test your configuration to be certain you have the correct versions of ffdshow, Haali, and AviSynth, and that all are working properly. Have you done that? Or tried another source file to see if AVCHDCoder chokes on that as well?
Maybe try BDRB instead?Pull! Bang! Darn! -
fritzi93,
Thanks for the lightbulb moment!!
I wasn't aware of the test facility in AVCHD, when I tried it, the conversion failed.
I have uninstalled AVCHD and all plugins, carried out a full re-installation and my videos are being processed correctly.
Thanks again
time2innov8 -
Yeah, all the free Blu-Ray to Blu-Ray programs are a little touchy. Glad you're sorted out.
I suggest you try BDRB as well. The differences are more in the GUI (and presets) than in quality, since both use the same "toolkit". The recommended versions of the helper programs are different, but it's probable that BDRB will work fine if AVCHDCoder is set up properly. At any rate, it would furnish a basis for comparison.
Good luck.Pull! Bang! Darn! -
AVCHD looks like it could be a brilliant application, but I get error code 0401 every time. A fresh install of Windows still gives me error code 0401, tried it on another machine and it's the same.
The developer's site suggests it may help to update ffdshow. It also recommends to uninstall some specific codec-packs mentioned in the installation pdf: http://tools.twanwintjes.nl/uploads/AVCHDCoder/Guides/Installation%20Guide%20%28English%29.pdf
However, did you check if AVCHDCoder is "allowed" to use ffdshow in the video-configuration --> directshow control? Maybe that helps?
Cheers
Ennio
Edit: MediaInfo says about the testfile you uploaded that the format is main@L4.2
Don't know for sure if it has something to do with the error code, but can AVCHDcoder or ffdshow handle that kind of input - or maybe isn't set to do so?
By the way I re-encoded your testvideo with VidCoder and had no problems.Last edited by Ennio; 25th Jun 2012 at 09:21.
Not to resurrect a long dead thread, but I also had the errorcode 0x0401 and got here via googling the code. After updating all plug-ins, etc etc I was still throwing the errorcode. I used the decoder tester and found 64bit fail consistently. I unchecked the 64bit mode in settings, ran the tester on 32bit, and all is good.
Maybe 64bit is still a tad touchy in beta, or ...
geoff
ProjectX (errorcode: 24 problem)
By twinaleblood in forum Video Streaming DownloadingReplies: 0Last Post: 16th Jan 2012, 09:15 -
Video Pixelation Converting MKV To AVCHD Using TSMUXER
By uscstyle in forum Video ConversionReplies: 26Last Post: 1st Apr 2011, 19:29 -
Error -1856: An Unknown error occured
By Tyler2000 in forum Software PlayingReplies: 2Last Post: 27th Oct 2010, 19:55 -
Mpeg2schnitt 0.9.0 errorcode 113328 ?
By bahjan in forum EditingReplies: 3Last Post: 5th Oct 2010, 09:12 -
Two Pass encoding error
By iSherbiny in forum EditingReplies: 0Last Post: 10th Jan 2010, 06:14
