I have a Pansonic DMC-TZ5 digital camera that films movies in a .MOV format and apparently in HD, I have two queries:-
Query 1
Can someone recommend a free software tool that will allow me to convert from .MOV to .AVI so that I use the .AVI version within Windows Movie Maker, Windows Media player etc.
Query 2
As the .MOV movies are supposed to be HD quality and viewable in HD on an HD TV, will the conversion to .AVI via software on the PC still retain the HD quality so that I can specifiy HD quality when cutting the movie to a DVD?
These may seem very basic questions, but I would really appreciate some advise.
1. Try mp4camtoavi. If it fails try freemake video converter, xmedia recode or mpeg streamclip.
2. Yes. But if you make standard dvd-video it wont be any HD quality. -
I THOUGHT I WOULD DOWLOAD FREEMAKE VIDEO AS IT LOOKED EASY TO USE BUT ENDED UP WITH THE PROBLEM DETAILED BELOW SO SEND AN EMAIL TO THE SUPPORT EMAIL ADDRESS BUT TODATE NO REPLY.
Hi,
Can you please assist, I downloaded version 2.1.5 of Freemake Video, because it looks simple to use but having copied a .MOV and then requesting conversion to .AVI, the conversion states successful but when the resultant .AVI is viewed there is no sound.
The original .MOV when copied into Freemake prior to conversion states MJPEG & PCM_U8.
I have also uploaded the original .mov to filefactory.com, the identity is shown below:-
P1000152.MOV
http://www.filefactory.com/file/cb9bc6b/n/P1000152.MOV
I really hope you can assist as I want to be able to use your software to convert from .mov
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
Canon 7D MOV 1080p files problem getting quality H264 conversion
By lostinvideo in forum Video ConversionReplies: 3Last Post: 11th Nov 2009, 10:16 -
.avi to .mov conversion nightmare
By towarmforacoat in forum Video ConversionReplies: 4Last Post: 20th May 2009, 15:16 -
Having trouble with a conversion (mp4 / avi / mov / flv)
By loxley in forum Video ConversionReplies: 4Last Post: 23rd Feb 2009, 11:17 -
AVI to .Mov conversion
By HD_Shooter in forum MacReplies: 10Last Post: 18th May 2007, 07:45
