what Iam after is to be able to author my own 720p videos for youtube but I want those videos to have lossless audio... I already have the lossless audio and would like to create a video with some simple images to upload to youtube (its all about the audio on this one) - in 720p YT compresses to 152k AAC (or 192k Vorbis on html5) - I want to upload the video with the lossless audio so they are compressing from that rather than another lossy source
I have been using Windows Live Movie Maker... BUT... it does not support lossless audio and take an absolute AGE to encode videos...
something that can take two images and display the first image for 10 seconds and 2nd image for remainder of video (or set time) and then mux the lossless audio into it
any ideas?
thanks
im finding Vegas a wee bit difficult
ive managed to insert audio track with my wav file and drag pictures to time line and stretched out - but when i RENDER AS it only exports the transition even between the two images? and thats 6 seconds of video in 88Mb in size?
is there anything as simple as Windows Live Movie Maker but has lossless audio support and encodes at real speeds
edit: you cant set the bitrates either, you can only choose an SD profile or an uncompressed HD file which isnt what I want, I need low bitrates on video file and lossless audio
edit: sorry, i just seen the custom option and i think ive sussed the yellow drag marker arrows - outputting Xvid 720p with PCM audio nowLast edited by snadge; 29th May 2011 at 16:54.
mmm im not really after high quality video - just fast encoding, the video is only a still image so only needs low bitrate but must be 720p so i can have option of the lossless audio to be compressed into 152Kbps AAC (or 192Kbps Vorbis on html5) as opposed to 128Kbps AAC for 480p or 360p videos
thanks for your help, this VEGAS is spot on, much quicker and gets the result im after - just uploaded the video to youtube too and works a charm
THANKS AGAIN
AVCHD editor Sofware with lossless video output,which can handle PSF format
By Stears555 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 14th Feb 2012, 03:56 -
Lossless AAC file editor?
By sldvd in forum AudioReplies: 1Last Post: 26th Oct 2010, 18:28 -
AVS Video Editor - jerky on BD-RE footage created. AVS4YOU support poor.
By rjamesd05 in forum Authoring (Blu-ray)Replies: 13Last Post: 26th Mar 2010, 07:03 -
DVD creator that support MTS video files
By 1234567 in forum Authoring (DVD)Replies: 3Last Post: 19th Jan 2010, 20:07 -
Creating youtube clips using AVS Video Editor 4.1
By imrealdumb in forum Video Streaming DownloadingReplies: 1Last Post: 12th Jun 2009, 08:27
