Whenever I try to convert a video with Any Video Converter, it ignores what codec I choose and makes the avi video codec FMP4 and uses the writing application Lavf52.82.0.
How do I get rid of whatever this stupid writing application is? I want the xvid codec, not whatever FMP4 is.
Hi
Your AnyVideoConverter program is using FFmpeg to do the converting.
That's where the 'Lavf52.82.0' comes from.
And FMP4 is FFmpeg's built-in MPEG-4 video codec.
So, if you definitely need to use a different codec, then do as Baldrick suggested - use a different program.
Name of Application
By PC_Tek in forum Newbie / General discussionsReplies: 24Last Post: 16th Feb 2010, 16:54 -
Application Error
By Jmorales27 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 10th Jul 2008, 15:35 -
Where is the coupon application?
By moviebuff2 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2008, 14:15 -
COLOR application
By Tom in HD in forum MacReplies: 2Last Post: 2nd Dec 2007, 01:09 -
reg the application to use
By liddu in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2007, 04:31
