can any one tell me how to convert M2TS files to mkv with truehd audio.
Results 1 to 9 of 9
Add m2ts in tsmuxer, choose demux. Add the separate streams files in mkvmergegui(mmg). Save as new mkv.
Or if you want to shrink the m2ts to a smaller mkv then try handbrake or freemake video converter. -
another question is the video of a mkv as good as a m2ts file.
Yes, if you just use tsmuxer and mkvmergegui it will be same quality. If you shrink it you will lose a bit quality.
okay tis is working pretty good but i have one question should i be changing the FPS
Help with multiple .m2ts files to one .m2ts
By neworldman in forum Blu-ray RippingReplies: 10Last Post: 4th Sep 2013, 10:16 -
mux m2ts to m2ts with AC3 audio without reencoding the video
By BirdDaddie in forum Video ConversionReplies: 3Last Post: 22nd Aug 2010, 21:19 -
Edit M2TS and saving it as M2TS
By Andreas Furumo in forum Video ConversionReplies: 3Last Post: 28th Aug 2009, 14:07 -
Remux m2ts with DTS to m2ts
By eummagic in forum Blu-ray RippingReplies: 9Last Post: 13th Mar 2009, 20:03 -
shrink .m2ts to smaller .m2ts
By inano in forum Blu-ray RippingReplies: 2Last Post: 14th Jan 2009, 08:50
