So I just got a Hauppauge HD PVR and I can't get the Xbox to show up, I've tried hooking up my direct tv receiver and the PVR worked fine. And the Xbox YPbP1 wires work fine in my TV but nothing when pluged into the PVR. Would love some help with this problem.
The hdpvr can only record 1080i or lower - make sure you have your xbox set to 1080i or 720p before recording.
Also make sure the hdtv slider is slid all the way over - it could possibly be loose and not fully locked into the "hdtv" position.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The HD PVR is very picky about what it will record. The source must be 1080i at 29.97 fps or 720p at 59.94 fps (for HD). Many HDTVs will happily display a lot of other resolutions and frame rates.
Uh oh, does this fall in to the "warez" category? Who cares.Last edited by jagabo; 27th May 2011 at 20:03.
i need some help xbox 360 hauppauge hd pvr...
By xxxxdrakexxxx in forum Capturing and VCRReplies: 3Last Post: 21st Dec 2011, 19:12 -
Hauppauge HD PVR
By Susan_T in forum Video Streaming DownloadingReplies: 1Last Post: 21st Nov 2011, 20:06 -
Need help with Hauppauge HD PVR + Xbox 360
By epikool in forum Capturing and VCRReplies: 16Last Post: 1st Nov 2011, 05:37 -
Xbox 360 - Hauppauge HD PVR 1212 - Please Help
By twblindv2 in forum Capturing and VCRReplies: 1Last Post: 14th Apr 2010, 16:29 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 09:04
