I use Sony Vegas Pro (version 10d). I have a video witch take with my camera with duration about 60 minutes.
This video shows one sunset.I place the camera still on a tripod shooting the sun for one hour.
I want to make a movie witch will show the sun go to sunset in very fast movement ( like fast forward) and the clouds around
pass very quicly!!
In witch way can i do this????
Results 1 to 10 of 10
You could try with a velocity envelope, which will let you speed this footage up by 100%, but I believe you will be better off processing this footage outside Vegas first - perhaps in avisynth or virtualdub - then bringing the finished results into Vegas to add to your final cut. Both have much better decimation capabilities than Vegas if you want to get 1 hour of footage down to only a minute or two (you don't actually say how long you want it to run for)
Read my blog here.
The Velocity Envelope gives you far more control, plus you can keyframe it to ramp in and out of the changes as necessary. I believe there is a difference in how the effect is rendered between the two methods as well.
Still, the OP loses nothing by trying both methods.
I stll think Vegas is limited on just how much change it can handle for a speed up, and 1 hour down to a minute or so is too big an ask. A proper decimation method is needed instead.Read my blog here.
What I do on stuff like that is time-compress it as far as it will go, then render to new track, then repeat as often as necessary.
A sunset will come out very nice because there is so little change between frames.
Multi-rendering to "distill" is useful for other things too. That's basically what you're doing is "reducing", like making a gravy, or thickening a soup.Last edited by budwzr; 1st Jun 2011 at 13:14.
Check out Corel Video Studio Pro X4. It states that it can do that.
http://www.corel.com/servlet/Satellite/us/en/Product/1175714228541#tabview=tab1
How to Edit DVD Menus incl overlay pictures over video Sony Vegas DvdRemake
By c627627 in forum Authoring (DVD)Replies: 2Last Post: 20th Feb 2011, 21:19 -
Sony Vegas Movie Studio 9 and in/out time of edit or substitute video?
By apollo1980 in forum EditingReplies: 5Last Post: 5th Jan 2011, 12:07 -
Sony Vegas does not show MP4 files
By morph8070 in forum Newbie / General discussionsReplies: 3Last Post: 16th Apr 2010, 15:02 -
No Sound, from tivo DVD recorded tv show, on Sony Vegas 8.0
By d00r in forum EditingReplies: 9Last Post: 24th Sep 2008, 15:13 -
Unable to edit .AVI using Sony Vegas 7
By CharisFilms in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2007, 03:50
