Results 1 to 12 of 12
  1. Hi., is there any setting in MPCHC to get best sound output just like power dvd 10..?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Audio settings are in the Options menu. S/PDIF selections show under DirectShow Audio ...
    http://www.kiva.org/about
  3. in my MPCHC i cant see Direct show Audio as per ur attached screenshot, where shud i enable it?
  4. its showing only audio renderer...........
  5. Member edDV's Avatar
    Mar 2004
    Depends on your sound chipset. This computer has the Intel High Definition audio chipset.
    In MPCHC, the DirectShow audio options are ...
  6. Member edDV's Avatar
    Mar 2004
    Maybe your sound driver is missing. What is the motherboard?
  7. Member edDV's Avatar
    Mar 2004
    FYI: Here are the menu selections for an older machine with Realtek AC97 audio chipset.
  8. Here are the details...
  9. and this is what my MPCHC shows..
  10. plz suggest any other options...thanks in advance..
  11. Member edDV's Avatar
    Mar 2004
    Does your computer have an S/PDIF or HDMI output? If so it isn't showing in the list.
    #6 gets best sound to the analog line/speaker output.
  12. Thanks..there's No S/PDIF Output,but there is a HDMI output. i usually watch movies using Genius DRD True 3D sound headset. Planning to install 5.1 speaker system in future.
