i really really need help converting these two movies they are smr and everytime i go to convert them i get these pink blurs in the final mpeg does any one hjere knw how to convert these movies so i dont get the pink blurs
the movies are the mothman prophecies and the queen of the damned
Results 1 to 13 of 13
Im having the same probalem as of late. I'll check if there SMR's when I get home.
One was Taps and the other was a porno.
I'll let ya know when I get home.
Ok just got home. Re-installed some codecs and the problem went away!!!
Give it a try!!!!
I just installed Nimo Codec pack, you can find it in the tools section under codecs.
-Hope this helps
i know if u installed the suck azz ANGEL POTION CODECS that it produces colored blurs
thanks ill try it
and i had angel potion before but i got rid of it as soon as i heard of its problems a long time ago -
I've the same problem with SMR movies since 5 days and I don't know what to do. I' ve installed, uninstalled, installed Nimo Codec Pack but it doesn' t help anything. I don' t know if I have installed that angel potion Codec, how can I find it? What else can I do if the angel potion Codec isn't the problem? I really need some help with that, please give me some instructions about what I can do?
Please!!
Hanselel -
the only thing i could do is completly uninstall all the codecs in my comp and convert it with virtual dub to be able to use it in tmpgenc
What do you mean with convert it with VIRTUAL DUB, what exact did you do?
Thanx Hanselel -
Look what happened to me when i opened Virtual Dub, I' ve got this message:
The "AngelPotion Definitive" codec has been detected on your system. This driver is an illegal binary hack of the following legitimate drivers:
* Microsoft MPEG-4 V3 video
The AngelPotion codec is a particularly poor hack of the MS MPEG-4 V3 codec and is known to cause a number of serious conflicts, including but not limited to:
* Excessive disk usage on temporary drive
* Incorrectly responding to compressed formats of other codecs, even uncompressed RGB
* Preventing some applications from loading AVI files at all
* Inhibiting Windows Media Player automatic codec download
The author cannot guarantee the stability of VirtualDub in any way when AngelPotion is loaded, even if the codec is not in use. All crash dumps indicating AP is loaded will be promptly discarded. It is recommended that you uninstall AngelPotion when possible.
This is only a warning. Aside from bug workarounds and warnings, VirtualDub does not take further action in response to AngelPotion being loaded
My question is how do I find that Codec on my Computer to uninstall it?
Thanx Hanselel -
just go to add/remove program and uninstall it then try it again itll work then after that you will be able to open it in tmpgenc with no pink blurs
while converting selenct full process mode for video and audio and direct stream or quick recompress and then file save avi and your done
Pink hue on TV
By uniks in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2011, 07:00 -
fast action blurs
By johnsees in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2008, 01:23 -
When certain subs appear, the whole screen goes pink
By oldjoe911 in forum SubtitleReplies: 1Last Post: 9th Sep 2008, 18:14 -
When playing video everything is PINK?!
By shorto in forum ComputerReplies: 6Last Post: 24th Dec 2007, 14:20 -
pink snow from dvp3960
By warr in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Nov 2007, 14:11
