  1. To be honest, I have no clue what is causing Ripbot to act so strangely. At the moment, Ripbot launches with no icon on the taskbar. Also, when trying to encode Spider-Man to an mkv file, I get the message "avs2yuv has stopped working". This happens every time I try to encode, and at different points during the process. It has gotten as far as 90% finished before I get the message. Then, I tried using Handbrake to encode the file. When I did this, the file worked, with an 10.9gig output. However, with my luck, playing the file through PS3 media server had a bitrate of about 100mbps. I'm no expert, but that type of bitrate should have made a much larger file. Needless to say, not even my hardwired connection could handle it. Please help, usually I don't ask for it, but I'm starting to get frustrated. I also apologize for being unorganized.
  2. jandor2009
    Apr 2010
    Brazil
    You can also go to the page of the RipBot264: http://forum.doom9.org/showthread.php?t=127611
    Certainly you will have their solved problem.
