Page 3 of 3
FirstFirst 1 2 3
Results 61 to 69 of 69
  1. Would converting to an mp4 container be any different?
  2. Originally Posted by shaunthesheep View Post
    I managed to convert to wav OK using your string and it imports into Lightworks OK with all 6 channel intact and audio playback excellent. Progress. Many thanks.
    This suggests that lightworks' MOV parser is buggy , you should report these observations to the developers
    When people use DNxHD, it's usually in MOV container with uncompressed audio - so those people are going to have problems.
    PCM WAV is poorly supported in MP4 container
  3. Like I said in post 56, I have raised it in the Lightworks forum as a possible bug. However, at least one person has managed to import a mov file into Lightworks with 6 channel pcm audio so matters are not clear cut.
  4. You have to compile it from the sources. The one I compiled the other day doesn't have AAC support. (You can include whatever external libraries you want)
    @poisondeathray. Is there any chance you could allow me to use your ffmbc 0.6 compilation?
  5. Originally Posted by shaunthesheep View Post
    This one is compiled with no external libraries, only avisynth support
    ffmbc-0.6-rc6-static
    http://www.mediafire.com/?l3m7w3np1xr3iv6
  6. Many thanks.
  7. A Lightworks user has also complied FFMBC v6 and it can be downloaded here.
  8. btw 0.6 rc7 was released yesterday
    unspecified bug fixes on the changelog
    FFmbc-0.6-rc7
    - Options are now reset between -i, output files and
    -newaudio, -newvideo parameters.
    - Display starting time code for MXF and Quicktime files.
    - Bug fixes
  9. A Lightworks user has compiled ffmbc 0.6 rc7 here.
