I have been beta testing the new and soon to be open source Lightworks NLE and trying to find a way of helping people to convert from AVCHD MTS to a format that it can handle. Lightworks can currently handle AVCHD in QuickTime containers but not MTS. I found a way of re-wrapping MTS to mp4 using Mediacoder but it doesn't work consistently so I am looking for a more reliable method.
But even if users do succeed in re-wrapping their files, they don't always play back smoothly in Lightworks except on the most powerful PCs (although long GOP performance is on the developers' roadmap). Intra-frame codecs like MPEG I-frame HD are much easier to work with. Lightworks uses the Matrox VfW codecs and can transcode to MPEG I-frame HD on import. So what some people have been doing is re-wrapping MTS to mp4 and then transcoding to MPEG I-frame on import into Lightworks
I am looking for a way to
a) re-wrap from mts to mp4 or mov.
b) transcode from mts to MPEG I-frame HD in an AVI container.
I have been searching the forum for a way of doing the latter and I found various threads dealing with conversion from MTS to other formats. I found this thread on converting from MTS to MPEG I-frame but in an m2v container. I tried changing mkv to avi in the MPEG I-frame bat file and it did indeed create an avi file. However, when I imported it into Lightworks, the video was black.
I would grateful for any suggestions.
Results 1 to 30 of 69
MPEG in AVI is very unusual but: VirtualDub + ffdshow
Also look at AviDemux.Last edited by jagabo; 26th May 2011 at 12:35.
As I understand it, Virtualdub is a Video for Windows app and can't open MTS files. Correct me if I am wrong. How exactly does ffdshow fit in?
Lightworks at the moment has a limited range of supported codec/container combinations. It just so happens that it supports MPEG I-frame SD and HD in an AVI container (using the Video for Windows Matrox codecs).
Lightworks is scheduled to become open source in the summer 2011. It isn't OS yet and until it is, common GPL style licensed toolkits and libraries are not an option. At the same time proprietary libraries have to be removed/replaced before it is Open Sourced. Which leaves the current chain of beta releases with a very small choice of external libraries.Last edited by shaunthesheep; 26th May 2011 at 12:48.
if lightworks accepts avchd re-wrapped in mov, then you can use ffmpeg (you don't need ffmbc)
ffmpeg -i input.m2ts -vcodec copy -acodec copy output.mov
do some quick tests, if this works for lightworks, you can write a batch script
matrox vfw codecs are free, you can access it through vdub or any NLE based on vfw framework
http://www.matrox.com/video/en/support/windows/vfw_software_codecs/downloads/softwares/version1.0/
to load avchd into vdub, you can use avisynth to frameserve -
The MTS files I am dealing with have ac3 audio which needs to be transcoded to aac. Only the video is re-wrapped. Sorry, should have made that clear. We have come across a long standing bug in FFMPEG which has created problems doing this.
See this thread in the Lightworks forum.Last edited by shaunthesheep; 26th May 2011 at 13:44.
why is aac required or even preferred ? it's lossy format
or is this a lightworks issue ?
why not uncompressed ?
if you're copying the avc video stream, you're still going to have performance issues (I doubt lightworks is optimized for decoding/performance of avc streams)
why not something like dnxhd ? -
Not sure. Just guessing but isn't AC3 proprietary (Dolby)? Lightworks is currently being stripped of proprietary code and libraries prior to being released as open source.
As I said earlier, Lightworks long GOP performance improvement is on the development roadmap. My quad core PC struggles to play back AVCHD in Lightworks (though it plays OK in VLC). MPEG I-frame HD plays much better with little loss in quality.
So what I have been doing is re-wrapping MTS video to mp4 and transcoding ac3 to aac, Then transcode to MPEG I-frame HD on import into Lightworks.Last edited by shaunthesheep; 26th May 2011 at 14:03.
Yes AC3 is Dolby, but DEcoding AC3 is not a problem for GPL or opensource , free software. Even ENcoding AC3 is free and legal with aften without a license
But AAC audio has licensing issues, and ffmpeg cannot be distributed with it. (If you compile it yourself from the sources, it's ok). ffmpeg's AAC audio encoder is very low quality compared to nero's or even FAAC, so you probably wouldn't want to use it anyway
I would use uncompressed audio
ffmpeg -i input.mts -vcodec copy -acodec pcm_s16le output.mov
If you still get performance scrubbing issues for the video, try something like DNxHD. (you can encode through ffmpeg as well, there are links and instructions in that thread you linked to in the 1st post)
If you still have problems, then use the matrox mpeg2 i-frame suggested earlier through vdub and avisynth. -
I just tried it on an AVCHD clip and it worked for me . It even opens in quicktime
upload a sample clip from your camera (what model) . If it's <30MB you can upload directly here, otherwise use a free hosting site e.g. mediafire.com, sendspace.com etc...
If you end up taking this route - you don't need these intermediate formats, you can go directly to MPEG2 I-frame with avisynth/vdubSo what I have been doing is re-wrapping MTS video to mp4 and transcoding ac3 to aac, Then transcode to MPEG I-frame HD on import into Lightworks.
Presumably, once you settle on a format and workflow, you would want to batch everything (E.g. convert all the videos in a folder), not sit and wait to convert things 1 by 1. FFMPEG is easy to setup batch scripts because it work with command line. There are avisynth and vdub batch workflows as well , but they take extra steps -
Many thanks for your help. I really do appreciate it.
Still no joy. I tried it with another AVCHD file from another camera with exactly the same result
Let me just check that I am doing the right thing.
I have an AVCHD file named tom.mts in a folder with ffmpeg.exe. I create the following string in a text file in the same folder:
ffmpeg -i tom.mts -vcodec copy -acodec pcm_s16le tom.mov
I save the text file with this string and rename the file extension to .bat.
Click on the bat file and a mov file is created named tom.mov but it is only 161.kB in size.
I am used to using Virtualdub but AVISynth (which I have on my system) and frameserving remains a mystery to me (I have a vague idea what it is but that is all). I am just reading about it now elsewhwere on the site to re-fresh my memory. I think it is absence of a GUI that is the problem with AviSynth.
Here is one of the AVCHD files at Sendspace.Last edited by shaunthesheep; 27th May 2011 at 03:36.
Here are MediaInfo results for the two AVCHD files.
General
Complete name : C:\Users\username\Desktop\avchd_conversion_batchfi les\tom.mts
Format : BDAV
Format/Info : Blu-ray Video
File size : 326 MiB
Duration : 2mn 37s
Overall bit rate : 17.3 Mbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=26
Codec ID : 27
Duration : 2mn 38s
Bit rate mode : Variable
Bit rate : 16.2 Mbps
Maximum bit rate : 16.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.312
Stream size : 305 MiB (93%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 2mn 38s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -80ms
Stream size : 8.44 MiB (3%)
General
Complete name : C:\Users\username\Desktop\Lightworks\Video samples\Stefan MTS\00076.MTS
Format : BDAV
File size : 75.0 MiB
Duration : 39s 786ms
Overall bit rate : 15.8 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=24
Codec ID : 27
Duration : 39s 760ms
Bit rate : 14.9 Mbps
Maximum bit rate : 16.8 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.288
Stream size : 70.7 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 39s 872ms
Bit rate : 256 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 1.22 MiB (2%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 39s 296ms
Delay relative to video : -80ms -
I tried using the Windows command prompt to run the FFMPEG string to see if it shed any light on why it was not working. I navigated to the directory where the files were and this is the result (see below).
Several people at the LIghtworks forum have tried using FFMPEG commands to convert mts files to mp4 or mov (see link in earlier post for an example) and they always get this same error: [mov @ 018355e0] Application provided invalid, non monotonically increasing dts
to muxer in stream 0: 1 >= 1
One of the Lightworks forum users looked into it and apparently it is down to a long standing bug in FFMPEG.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\user>cd desktop
C:\Users\user\Desktop>cd avchd_conversion_batchfiles
C:\Users\user\Desktop\avchd_conversion_batchfiles> ffmpeg -i tom.mts -vcodec cop
ffmpeg version git-N-30172-g3c20c0e-Sherpya, Copyright (c) 2000-2011 the FFmpeg
developers
built on May 24 2011 03:24:39 with gcc 4.2.5 20090330 (prerelease) [Sherpya]
libavutil 51. 2. 1 / 51. 2. 1
libavcodec 53. 6. 0 / 53. 6. 0
libavformat 53. 2. 0 / 53. 2. 0
libavdevice 53. 0. 0 / 53. 0. 0
libavfilter 2. 10. 0 / 2. 10. 0
libswscale 0. 14. 0 / 0. 14. 0
libpostproc 51. 2. 0 / 51. 2. 0
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 50.00 (50/1)
Input #0, mpegts, from 'tom.mts':
Duration: 00:02:38.08, start: 1.000033, bitrate: 17306 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:
9], 50 fps, 50 tbr, 90k tbn, 50 tbc
Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.2[0x1200]: Subtitle: pgssub
Output #0, mov, to 'tom.mov':
Metadata:
encoder : Lavf53.2.0
Stream #0.0: Video: libx264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], q=2-31,
25 tbn, 25 tbc
Stream #0.1: Audio: pcm_s16le, 48000 Hz, 5.1, s16, 4608 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop, [?] for help
av_interleaved_write_frame(): Invalid argument
C:\Users\user\Desktop\avchd_conversion_batchfiles>Last edited by shaunthesheep; 27th May 2011 at 06:26.
Well, the "normal" prebuilt ffmpeg binaries can convert AVCHD from other cameras, but they seem to have problems with your clip. It just might be that particular snapshot/date. Certain versions might work better than others
ffmbc works on it however
it you want to make a batch file (I would test 1 or 2 clips in lightworks before converting a whole bunch)
for %%a in ("*.mts") do ffmbc -i %%a -vcodec copy -acodec pcm_s16le %%~na.mov
pause
But I'm willing to bet editing performance in lightworks is going to be slow, even worse so if it's using quicktime API to decode these -
The error has been present with several AVCHD MTS files from different cameras that we have tried to convert. It is a known FFMPEG bug. See here and here.
This is what one of the Lightworks forum users says about it:
Given that for the time being at least AVCHD is not going to play back to well in Lightworks unless you have a top of the range CPU, I think it would make more sense to convert to MPEG I-frame HD."I investigated this error a bit and found there is a long lasting bug in FFMpeg itself. Any command which contains '-vcodec copy' or '-acodec copy', executed on a file coded with H.264/AC-3 ends up with 'non monotone timestamp' error message. It's well documented in the Web and officially reported as a pending bug. It's pending since years, so I guess it's a very low priority for FFMpeg devs. So any converter based on FFMpeg is unsuitable here."
Is there an FFMBC binary for Windows? The one I cam across appears to be for Linux and needed compiling.
EDIT
I have found the FFMBC for Windows.Last edited by shaunthesheep; 27th May 2011 at 10:29.
Well it definitely works with ffmbc on your test clip, even QT opens it up , and the "normal" ffmpeg definitely works on several AVCHD clips from other cameras I tested (mostly Canons)
Did you test it ? Some NLE's have optimized AVCHD playback and support (e.g. Edius) , and even on "average" hardware AVCHD plays back smoothly. Maybe it's in the development schedule for lightworks ?
Another option might be a proxy workflow, to edit at lower res, then swap back in the high quality version on final render. If those mov wrapped videos are accepted, that could be your online version. FFMPEG could be used to generate batch proxies as well. Most NLE's have some form of offline workflow where you just right click and they swap back in the high quality version -
To generate batch scripts or batch proxies, "Khaver" has made some GUI's that do this. I think v1.6 is the latest if you scroll down the page in the link below
There are included pdf instructions, screenshots in the zip file
http://www.hv20.com/showthread.php?25044-Batch-Intermediate-Creation-Utilities/page4
So you might use batch avs creator to generate your avs scripts then vdub to batch encode your Matrox AVI files. There are several tools and tutorials to help batch work in vdub as well, search for "virtualdub batch" on google -
I have just downloaded FFMBC and managed to get convert a mov file that plays OK in VLC. Just testing with Lightworks...
EDIT
The converted mov imports into Lightworks but there is no sound. Visual playback is a still image. I transcoded to MPEG I-frame HD on import and the video plays OK but with no sound.
I am just wondering if QuickTime for Windows can handle PCM audio? I don't even know if it can handle AC3--that was why we converted to aac with Mediacoder. The original audio in the file I am testing is 5.1 surround sound. The converted mov is stereo audio. Is there a command to keep the 5.1 audio in the converted file?Last edited by shaunthesheep; 27th May 2011 at 11:05.
It works in Quicktime for Windows here, audio & video
Your file you uploaded was stereo, and the converted file is stereo
I am using ffmbc 0.6rc6
Do you know how lightworks parses mov ? Does it use the quicktime framework or libav ?
"pcm_s16le" gives you PCM little endian or "SOWT" . This is completely compatible with quicktime
There are other types of uncompressed audio that you could try, but some of them are not compatible with QT
EDIT:
I just tested AVCHD 5.1 clip from a Sony camera, and it works with 5.1 PCM audio as well. QT sees 6 channelsLast edited by poisondeathray; 27th May 2011 at 11:11.
I pointed out VirtualDub and ffdshow earlier because VirtaulDub can open most files with the right source plugin. You can also use AviSynth to open any file with the right plugins. VirtualDub can save as AVI as you requested. ffdshow can encode for VirtualDub and has the ability to save as MPEG 2 with all I frames (in AVI). Short GOPs and IP frames only might be better though.
I don't know how Lightworks parses mov. I will ask the devs on the Lightworks forum and report back.
Well some NLE's have moved away from quicktime (because it's horrible software and full of bugs) - the newest versions of Premiere and Vegas no longer use QT API to decode .mov , and are much more stable because of it
If lightworks is moving to opensource, then chances are it will use libav like blender, and it should be able to import other formats (it should be essentially ffmpeg based)
I tested one of the early releases of lightworks... and it was just a mess. Definitely should not have been released as beta for public. I might test it again once it gets developed a bit more.
Another format you should try is DNxHD
I don't know how picky you are, but my concern about Matrox MPEG2 AVI is there is an intermediate RGB conversion. This causes clipping of superbrights/superdarks Y" <16, Y' >235 as the RGB conversion adheres to Rec601/709. The control panel allows some options, but you cannot encode through vdub keeping Y'CbCr (there is an error). If you don't "fix" the levels or adjust them to "legal range" before your conversion, you lose that data . And I couldn't find a CLI interface or any other way to encode without that incurring that intermediate conversion. It's the same thing if you use it through an NLE like vegas or premiere. Even when functioning in Y'CbCr mode, there is evidence that exported file has undergone an intermediate RGB conversionLast edited by poisondeathray; 27th May 2011 at 11:29.
Lightworks is in a transitional state as I mentioned earlier. It is being stripped of proprietary code but because it is not yet open source it cannot use GPL libraries either.
I have just installed the FFDshow plugin for Virtualdub but it still does not open mts files.
Install the Directshow source filter. Or use an AviSynth script to open the file for VirtualDub.
Mediainfo reports that the converted mov file has 6 audio channels yet when I import it into Lightworks it has only 2. There is some audio "noise" when I play it back in but it is just occasional and faint--nothing like the actual audio,
Could you give me a link for the Directshow source filter please--I can't locate it on the web.
Short sample of MPEG2 in AVI from MTS source. Via Haali + VirtualDub (DS source plugin) + ffdshow.
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 03:42 -
Frame rate fore converting MTS video to avi
By nicholasrumin in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 13:57 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Converting/editing MPEG-TS container with AVC/AACvideo
By Omega81 in forum Video ConversionReplies: 10Last Post: 28th May 2010, 17:03 -
Problem while converting MP4 container into avi
By Fire Foxer in forum Video ConversionReplies: 4Last Post: 29th Nov 2009, 15:55
![Computer details: Windows 7 Home Premium 64 bit SP1, DirectX 11, Ubuntu Studio Linux 11.04, QT Pro 7.6.9, Dell Inspiron Desktop 560 MT motherboard, Intel® Core™ 2 Quad-Core Q8300 Processor (2.50GHz, 4MB cache, 1333MHz FSB), 6144MB Dual Channel DDR3 [2x2048 + 2x1024] Memory, ATI Radeon™ HD 5450 1GB DDR3 graphics card, WDC WD1001FAES-75W7A0 3.5 1TB internal SATA hard drive 7200 rpm, Toshiba 3.5 1TB external SATA drive 7200 rpm, Seagate Free Agent 3.5 500 GB external SATA drive 7200 rpm. Panasonic NV-DS28B, HM903DTA Vision Master Pro 454 19 inch CRT monitor, screen resolution: 1080 x 1024, onboard Realtek HD Audio. Comp](/images/buttons/computer.gif)
