I was using GfD to author a DVD with subs.
There were no errors reported, it muxed the AC3 audio and M2V video and then the SRT subtitles into an MPEG.
But it immediately aborted when it stared to create VOBs, with the error:
If I removed the sub from the project, it went to a complete VOB set. If I used that subtitle with another video file, it crashed as above.Code:STAT: Processing q:\DVD\Temp\21_~_F_SUB1.mpg... ERR: SCR moves backwards from 146 to 0
But there were no errors in the SRT. No problem in Subtitle Workshop or Subtitle Creator.
Eventually I realised there was something unusual though, the first sub began at exactly zero:
I changed the start time and it worked fine.Code:1 00:00:00,000 --> 00:00:01,352 Blah blah blah
Posting this to document the problem and workaround.Code:1 00:00:00,100 --> 00:00:01,352 Blah blah blah
Results 1 to 1 of 1
Error loading .sup files to GfD?
By michcio in forum SubtitleReplies: 0Last Post: 13th Dec 2009, 13:08 -
GfD - Subtitle error
By michcio in forum Authoring (DVD)Replies: 14Last Post: 4th Jul 2009, 10:17 -
GfD Muxman Error
By michcio in forum Authoring (DVD)Replies: 2Last Post: 14th Jan 2009, 13:11 -
"ERR: MuxMan error!" while Creating DVD in GfD
By michcio in forum Authoring (DVD)Replies: 2Last Post: 6th Dec 2008, 19:05 -
GfD timecode error
By bratpop in forum Authoring (DVD)Replies: 3Last Post: 5th Jan 2008, 10:53
