Hi there,
I'm a newbie here, so thanks in advance for anyone who can help me from loosing the plot with some video conversion I need to get my head around.
Basically I have some very strict video conversion parameters to adhere to, and Quicktime Pro, and a host of other converters I've tried just don't accommodate. I was hoping that someone might be able to point me in the direction of a (Ideally free, though not imperative) conversion app that does it all.
I absolutely HAVE to be able to fettle with the following for my target outputs;
Video:
Sound:
- File Format (Mp4 and 3gp)
- Frame Size and progressive scanning
- Max file size indication would be helpful so I know how big, in Mb, the target video will be
- The ability to crop to any screen size
- De-interlacing of target files
- Codec (H264, H264HD, H264BP and MPEG-4)
- Profile (Baseline, Baseline Level 3.1, Profile 0 and Simple)
- Frame rate (from 15 to 30 fps)
- Max Bit rate
- B-Frames
- Reference frame
- I-frame interval
- Format (AAC and AAC-LC (48Khz))
- Stereo or Mono
- Bit rate (Variable or fixed, 64 to 160bps)
As I mentioned, I have found some apps that do some of the above parameters, but none that can handle it all.
Am I asking too much here? Or is there a great app (Free or Paid) that will save my sanity and allow this level of tweakage?
Many thanks for any help anyone can offer.
Regards,
Paul.
Maybe AVIDemux? Most times there is never a single program that will do 'everything' and do it all well.
Being able to accurately control output size usually requires a two pass encode. Some of those other 'tweaks' are dependent on the codec settings themselves and not the program used.
And welcome to our forums.
Can cable converter box power on with specific channel
By vcd_user in forum Off topicReplies: 2Last Post: 14th Nov 2011, 20:06 -
Can't find converter for mkv files that works...
By Syyner in forum Video ConversionReplies: 1Last Post: 16th Sep 2011, 15:21 -
MKV Conversion; Very Specific.
By Miaoven Winter in forum Video ConversionReplies: 3Last Post: 27th Dec 2010, 03:43 -
audio cuts out in staxrip conversion
By RH7162 in forum Video ConversionReplies: 0Last Post: 5th May 2009, 19:40 -
Streaming to PS3...what are the specific file specs it wants?!?!
By N8theGr8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 1st Aug 2008, 14:43
