I have converte the SVCD file to MPG-2, how the how-to explain, but when i want to open in VirtualDub, give me a error message "Sychncronixation error bla bla" :) what can it be ?
I have follow the how-to but it doesn't work :\
Virtua dub almost allways gives a error, but it works just the same, just ignore it, it is most likely the sound that it has problems with, so search this site, and you'll find an answer to that problem too (I can't remeber where, but i found it here) Just remember: If you choose to rip the sound, and lay it on again, choose NO compression, otherwise you'll get bad syncronisation on the sound.
Hope this helps youReg'z
{Firefly}
Conversion Problem
By Myrdivar in forum Video ConversionReplies: 3Last Post: 2nd Jun 2011, 05:44 -
Problem with conversion to DV
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 09:54 -
conversion problem
By thomeski in forum Authoring (DVD)Replies: 2Last Post: 25th Apr 2010, 21:45 -
Help conversion problem!
By milney100 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 06:51 -
M4P Conversion Problem
By seven_deuce offsuit in forum AudioReplies: 3Last Post: 24th Sep 2007, 17:41
