Good evening, I would add two bluring on a video, here are his characteristics:
Format : BDAV
Format/Info : Blu-ray Video
Taille du fichier : 329 Mio
Durée : 4mn 28s
Débit global moyen : 10,3 Mb/s
Débit global maximum : 13,7 Mb/s
Vidéo
Format : AVC
Profil du format : Main@L3.2
Paramètres du format, CABAC : Oui
Paramètres du format, RefFrames : 2 images
Paramètres du format, GOP : M=3, N=30
Identifiant du codec : 27
Durée : 4mn 27s
Débit : 9 485 Kbps
Largeur : 1 280 pixels
Hauteur : 720 pixels
Format à l'écran : 16/9
Images par seconde : 59,940 Im/s
Espace de couleurs : YUV
Sous-échantillonnage de la chrom : 4:2:0
Profondeur des couleurs : 8 bits
Type d'image : Progressif
Bits/(Pixel*Image) : 0.172
Taille du flux : 302 Mio (92%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Extension du mode : CM (complete main)
Identifiant du codec : 129
Durée : 4mn 27s
Type de débit : Constant
Débit : 384 Kbps
Canaux : 2 canaux
Position des cannaux : Front: L R
Echantillonnage : 48,0 KHz
Profondeur des couleurs : 16 bits
Mode de compression : Avec perte
Taille du flux : 12,2 Mio (4%)
What video editing tool you advise me to do that quickly and simply (and especially without loss of quality)?
(I speak French)
Ps : I tried using VirtualDub but my video is not accepted
Thank you in advance
Two bluring? Blur two logos ? It would require reconversion = some quality loss. You could try use avidemux with the delogo filter, see http://www.youtube.com/watch?v=NTZsRHWMNxw
It isn't an mpeg2-ts file, and AVIDemux will have told you that you can't get smooth scrolling through AVC material in it's stable mode. You also haven't filled in your computer specs, so I have no idea if your PC is even capable of smooth handling of 720p AVC material.
That said, for simple blurring out a logo smooth playback in AVIDemux's preview windows isn't important. The choppiness will not affect the encoding.Read my blog here.
How to remove video blur?
By Djard in forum Newbie / General discussionsReplies: 10Last Post: 26th Aug 2010, 23:38 -
Blur small section of video
By zakman in forum EditingReplies: 4Last Post: 9th Mar 2009, 18:55 -
How to block out / Blur etc peoples faces on a video
By Raso in forum EditingReplies: 4Last Post: 30th Dec 2008, 20:23 -
youtube video is very blur!
By yunakokimama in forum Video ConversionReplies: 1Last Post: 14th Oct 2008, 15:16 -
Blur edge of video in vegas?
By macca1980 in forum Newbie / General discussionsReplies: 5Last Post: 29th Apr 2008, 02:37
