Hello,
I have a video and i use VirtualDub to change frame rate to 31.2500
From video menu i choice Frame Rate and change it to 31.2500
using Change frame rate to (fps) option. I didn't change the sound
setting just choice Direct stream copy option.
What should i do to fix the problem...?!
Video file info:
Code:General Complete name : 001.avi Format : AVI Format/Info : Audio Video Interleave File size : 372 MiB Duration : 21mn 30s Overall bit rate : 2 419 Kbps Writing library : VirtualDub build 33848/release Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Muxing mode : Packed bitstream Codec ID : XVID Codec ID/Hint : XviD Duration : 21mn 30s Bit rate : 2 279 Kbps Width : 1 024 pixels Height : 600 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.124 Stream size : 351 MiB (94%) Writing library : XviD 58 Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 21mn 30s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 1 channel Sampling rate : 44.1 KHz Stream size : 19.7 MiB (5%) Alignment : Split accross interleaves Interleave, duration : 33 ms (1.00 video frame) Interleave, preload duration : 500 ms
Best Regards,
SB4
I want to add another sound from other video file to the video above. To make the video match the audio file length...
Do you have another idea to make the sound has the same length as the video file...?!
the second video info is:
Code:General Complete name : 002.avi Format : AVI Format/Info : Audio Video Interleave File size : 59.1 MiB Duration : 21mn 41s Overall bit rate : 381 Kbps Writing application : MEncoder SVN-r22963 Writing library : MPlayer Video ID : 0 Format : MPEG-4 Visual Format profile : Simple@L1 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 21mn 41s Bit rate : 176 Kbps Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.023 Stream size : 27.4 MiB (46%) Writing library : Lavc51.40.2 Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 21mn 41s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Stream size : 29.8 MiB (50%) Alignment : Aligned on interleaves Interleave, duration : 26 ms (0.65 video frame) Interleave, preload duration : 522 ms
two films, both supposedly 25 fps, but audio tracks don't match?
By cinesimon in forum Video ConversionReplies: 4Last Post: 13th Apr 2011, 23:10 -
how to change frame rate on staxrip?
By VistaXP in forum Video ConversionReplies: 6Last Post: 6th Apr 2011, 15:13 -
Help with understanding when to change frame rate
By mlaran in forum Video ConversionReplies: 3Last Post: 22nd Feb 2010, 11:11 -
Scriptable tool to change AVI frame rate metadata?
By FurrTheBear in forum Video ConversionReplies: 4Last Post: 8th Jan 2010, 02:43 -
CCE keeps on trying to change my frame rate?
By friedtofublocks in forum Video ConversionReplies: 17Last Post: 14th Dec 2007, 06:21
