  1. Member brassplyer's Avatar
    Apr 2008
    Trying to get something to come out in 16:9 with Vegas Pro 8 using Huff, is it possible?
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    On Vegas 10 you can.
  3. Member brassplyer's Avatar
    Apr 2008
    Let me refine the question. Is it possible to create a 16:9 Huffyuv file at all, say using Virtualdub?
  4. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Yes, you can too.
  5. HuffYUV doesn't support aspect ratio flags. Just tell the editor the display aspect ratio is 16:9 when you open the HuffYUV file.
  6. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Assuming this is an anamorphic 720x480/576 file, in Vegas, right click properties and make sure aspect ratio is DV wide (e.g.16:9).
    If your file is square pixel ~1280x720, then make sure Vegas aspect properties show it as 1:1 square.
    http://www.kiva.org/about
