I have a bunch of episodic shows on dvd. I want to edit out the commercials and create a new dvd with menu. My dvd recorder is a magnavox mdr513h/f7. I used womble mpeg-vcr to cut out the commercials and create a .mpg file. for each title.
I found a simple, free program to author dvd with menus called, DVD Album 1.2.3.40
http://www.softpedia.com/get/Authoring-tools/Authoring-Related/DVD-Album.shtml
The description says, DVD Album will allow you to import several DVD .MPG video files, create a simple menu and burn them to a DVD video disc.
You can change menu thumbnails and captions, select the background picture and different video options.
Sounds perfect so I downloaded it, and I tried to open my .mpg video and I got the following message:
the selected mpeg-2 video file does not contain dvd-specific extensions
I don't know what that means. How do I correct it to make it compatible?
Is there a guide for this?
Thanks!
If your mpgs aren't dvd compatible( see www.videohelp.com/dvd#tech and identify your mpg properties with mediainfo) you must reconvert with for example avstodvd. It can output mpg files or to a dvd-video directly(with a simple menu).
Is anyone familiar with "Smooth Video Project"?
By jgg in forum Latest Video NewsReplies: 8Last Post: 22nd Sep 2012, 11:49 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 21:50 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 20:01 -
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 14:01 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 09:08
