Hey guys. I am a bit new to the conversion scene so any help would be great. I got a little ahead of myself trying to do some encoding, conversion etc on my own and now i am left with a movie that won't play on my xbox 360. I converted it to avi already but i may have missed something since it still will not work.
I have downloaded many of the free converters and codec packs necessary from the tips and site links on this website but i am now unsure what program and conversion type to use to get my ripped/converted movie playing. I know some conversions take long time so i can be patient. Here are my details and and any advice that will help me get this thing running on my 360 (without losing too much quality) would be awesome !! If you could also point out what may be the culprit of the current file not working on my 360 that would be great!! That way i keep learning more and more myself on what issues i may be having when ripping a movie and then trying to convert it to store on my external drives without screwing things up so much lol.
Format : AVI
File size : 358 MiB
Duration : 1h 40mn
Overall bit rate : 499 Kbps
Video
Format : AVC
Format profile : Main@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : H264
Duration : 1h 40mn
Bit rate : 360 Kbps
Width : 720 pixels
Height : 304 pixels
Display aspect ratio : 2.35:1
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.066
Stream size : 258 MiB (72%)
Writing library : x264 core 114 r1913 5fd3dce
Encoding settings : cabac=1 / ref=16 / deblock=1:-1:-1 / analyse=0x1:0x111 / me=umh / subme=9 / psy=0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=360 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=0
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 40mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 91.9 MiB (26%)
Alignment : Aligned on interleaves
Interleave, duration : 32 ms (0.80 video frame)
	Just choose a xbox 360 profile in handbrake, freemake video converter, etc. and convert.
	Wow as simple as that? I wish i would have come here first instead of fiddling with this last movie i ripped for the last 24 hours LOL. Most times i can rip and convert fine on my own but this one had me stumped LOL (probably my own fault for converting it into different formats before coming here. Ok let me give handbrake a try and thank you Baldrick
 Not sure which profile would work best for 360 in handbrake though. On the right hand side i don't have a specific preset for xbox but maybe i am missing something? I just want to make sure i dont convert this again and it doesnt work lol.
 I just went with normal under the "Regular" preset. I figure simple is the best lolLast edited by Cornholio77; 25th May 2011 at 06:30.
	As far as I know the 360 can't handle avc mpeg 4 video (at least not the times I've tried it on mine - the ps3 can not the 360). I believe there are "mpeg4" options. You should use that instead of avc.
 ---- I just checked - under the video tab use MPEG4 not h264 and you should be ok for the xbox 360. I don't believe the 360 handles h264 like the ps3 does. At least not in my tests but I may not have done it properly. But the 360 does play mp4 and divx and xvid I just don't think it likes h264.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	It supports h264 up to baseline and level 4.1 http://support.microsoft.com/kb/945416
 But I guess avi with xvid or wmv works a bit better. It's a kinda crappy media player though.
	Thanks baldrick. Maybe the encodes I had tested on it weren't to spec than. I might try again and see if I get a profile for both the 360 and ps3 - though I don't really have to since I have a wdtv media player - but good to know.
 Yes its not the best media player but if you own one and don't want to or can't buy a dedicated media player this CAN work.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	Thanks a lot for the info so far guys. I think i made a mistake though in my encoding and conversion. Handbrake converted the video file to m4v which the xbox won't recognize. If i play it using nero showtime on my pc it works great. But i only had 2 options under file container: MP4 or M4V. I suppose i was to choose mp4 and then once converted change the file extension manually to avi to play on the xbox? The audio of this file is fine for xbox though?
 Also do i have to change anything else then or i am ok once i put this back into an mp4 container? I am assuming my mistake was throwing it into an M4V container?
 HOLD THE SHIP !!!! I tried streaming the M4V container and it did not work however once i put it onto my external drive and played it, it works fine lol. Stupid xbox, i am very ready to just buy a stand alone media player at this point lol. The xbox works great to some extent when i want to play most of my dvd rips if they dont have alot of advanced codecs, but i am finding its a lot tougher to get it perfect when ripping my blu rays for conversion and back up purposes. But i should not complain i guess, since blu rays are meant to play on blu ray players so i guess not everything can go my way lol.
 The video is great for my ripped movie but the audio is about 2 - 10ths of a second off. No biggie, i am still happy to be able to rip these and have them stored forever without the fear of wrecking any more dvd's and in turn wasting more money. So thanks guys and it did work !! Now if i could only figure out why the sound is a touch out of sync
 Also can any of you tell me definitively why certain movies have no problem playing through external drives or usb but will not stream? I assume its a streaming issue due to windows or microsoft that does not exist once transferred to external devices?Last edited by Cornholio77; 25th May 2011 at 15:50.
  Why won't this MP4 work on my Xbox 360?By Jhay in forum Video Streaming DownloadingReplies: 2Last Post: 20th Dec 2010, 10:31
  Simple. Rip DVDs to lossless format that will stream to PS3 and Xbox 360By FuzzyReets in forum Video Streaming DownloadingReplies: 6Last Post: 2nd Sep 2010, 19:18
  how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19
  Extract subs from MKV (MKVextract doesnt work) and Re encode to xbox 360By Snipergod87 in forum Newbie / General discussionsReplies: 6Last Post: 6th Oct 2009, 18:51
  Capturing Xbox 360/Would This Work?By njosnavelin78 in forum Capturing and VCRReplies: 0Last Post: 4th Jun 2007, 01:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
