Can this be done? And if so, what programs should I use?
I want to put 3 to 5 SD movies or more of TV shows (in mpg ) on a BD disk with a menu that will let me select each individual movie. Something similar to what can be done with 1 or 2 movies on a DVD using DVDstyler or such.
DVD spec MPeg2 SD is supported. h.264 is supported if it meets Blu-Ray spec.
See "What is Blu-Ray?"
https://www.videohelp.com/hdRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Exporting a little movie file that won't consume my entire hard disk space
By Danny Pro in forum Video ConversionReplies: 5Last Post: 15th Feb 2010, 00:50 -
Can you author a Blu ray disk after rendering in Vegas Movie Studio.
By EagleW in forum Authoring (Blu-ray)Replies: 5Last Post: 18th Jan 2010, 20:37 -
Combining data files with a DVD movie on the same disk
By j_p in forum Authoring (DVD)Replies: 6Last Post: 26th Jun 2008, 02:52 -
Adding a menu to a dual-movie disk
By WHeisenberg in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2008, 15:29 -
Encore DVD 2.0 Movie location on disk
By thesixuk in forum Authoring (DVD)Replies: 2Last Post: 7th Aug 2007, 12:52
