I'm trying to convert a dvd into vcd. I know all the steps and even got the mpeg at the end from <TMPGEnc>. But when I played the file, there was only video and no audio.
on <dvd2avi> audio is track 1 and dobly is checked.
i dont know what the prob. is.
please give any suggestions.
thanks.
Try another audio track, remember DVD2AVI does not decode DTS tracks. Maybe track1 is DTS. If you use smartripper to rip, you can see all audio tracks at the "stream processing" tab. Newer versions even create a INFO.txt file.
So you don't need to check out every audio track.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 14:44 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
