Hi. For some reason, I was able to load and encode H264 videos just fine yesterday, but I couldn't today.
When I loaded a H264 video file, it says "Caching: attempted to read or write protected memory. This is often an indication that the other memory is corrupt."
I went on Google and searched around but couldn't find any good solutions. So I uninstalled Xvid4PSP and re-installed the latest version, which is 5.1. But the problem still persists.
I thought I may need to update my codecs so I installed all the latest codecs for both video and audio.
This time, I was able to load H264 videos, but a new problem arose: only audio was converted. Here's the error log I got from trying to encode a H264 video file:
PLATFORM
OS Code: Microsoft Windows NT 6.1.7601 Service Pack 1
OS Name: Windows 7 Ultimate Service Pack 1 (x64)
Framework: 2.0.50727.5420 (v4.0)
AviSynth: AviSynth 2.58 tsp MT version 5(mod seraphy), build:Jul 12 2009 [07:46:21]
CPU Info: AMD Phenom(tm) II X4 955 Processor (~3193), 4 core(s)
RAM Total: 7423Mb
Language: ENU (1252, ".")
SystemDrive: C:
XviD4PSP
Version: 5.10.234.0
Created: 14.04.2011 02:42:08
AppPath: C:\Program Files (x86)\XviD4PSP 5
TempPath: C:\Temp
FILES
[AM-A]Flames.of.Ambition.E24.450p-HANrel.AM-Addiction.avi >
TASK
Format: AVI
Duration: 01:07:58:120 (97777)
VideoDecoder: DirectShowSource
Resolution: 800x450 > 720x400
Aspect: 1.7778 > 1.8000
VCodecPreset: XviD Q3.0 HQ
VEncodingMode: Quality
VideoCodec: h264 > XviD (1.2.2)
VideoBitrate: 1550 > Q3.0
Framerate: 29.970 > 23.976
FramerateModifer: ChangeFPS
SourceType: PROGRESSIVE
FieldOrder: UNKNOWN
AEncodingPreset: MP3 CBR 128k
AudioCodec: AC3 > MP3
AudioBitrate: 192 > 128
Samplerate: 48000
Channels: 2
SCRIPT
import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\functions\AudioFunctions.avs")
import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\functions\VideoFunctions.avs")
loadplugin("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\plugins\VSFilter.dll")
DirectShowSource("C:\Users\Sau\Downloads\Video\[AM-A]Flames.of.Ambition.E24.450p-HANrel.AM-Addiction.avi", fps=29.970, convertfps=true)
ConvertToYV12()
###[FILTERING]###
###[FILTERING]###
Lanczos4Resize(720, 400)
TextSub("C:\Users\Sau\Documents\Flames.of.Ambition.E24.10 1226.HDTV.XviD-HANrel-[WITH S2].ass")ChangeFPS(23.976)
AUDIO ENCODING
Encoding audio to: C:\Temp\0001.mp3
MP3 128kbps 2ch 16bit 48000khz
lame.exe: -m s -b 128 -q 2 - "C:\Temp\0001.mp3"
VIDEO ENCODING
Encoding video to: C:\Temp\0001.avi
XviD Q3.0 720x400 23.976fps (97777 frames)
xvid_encraw.exe: -cq 3.0 -smoother 0 -max_key_interval 250 -nopacked -vhqmode 4 -lumimasking -max_bframes 1 -bvhq -bquant_ratio 100 -threads 6 -avi "C:\Temp\0001.avi" -i "C:\Temp\0001.avs"
Error:
Please help me. Thank you very much.
Results 1 to 10 of 10
it sounds like you should do a ram memory test. something like the bootable iso at http://www.memtest.org/
I ran the Memory Diagnostic Tool (windows 7 64-bit) and there was no problems with the memory.
I'm able to load xivd videos, but not H264 videos at high bitrates and resolutions. This is really weird. -
I think it's the program. I have tried different fifth versions, but it seems only version 6.0.3 Daily 2377 works for me. Do you know how to add subtitles for version 6? I can't find it anywhere. This one looks fancy but kinda hard to use.
@NoBuddy: Thanks but that doesn't work either
Another weird thing is that I'm able to load those H264 videos with VirtualDub and encode them, but not in Xvid4PSP. I think this has something to do with the recent windows updates I did. -
---deleted----
try a system restore back to when it all worked
PS - You're not allowed to cross post here...better erase your other post and insert "deleted" -
A system restore?? But... but I have done so many windows updates ... is that the only way out here? What if it doesn't work still?
XviD4PSP & Avidemux Doesn't work for me anymore.
By The_Jelly in forum Newbie / General discussionsReplies: 15Last Post: 14th Mar 2012, 09:05 -
xvid4psp settings to convert mp4 videos for SE w580i?
By secko in forum Video ConversionReplies: 2Last Post: 23rd Nov 2011, 11:27 -
XviD4PSP, VirtualDub or other app for fastest H264 hardsubbing
By ryukent in forum SubtitleReplies: 2Last Post: 26th Jul 2011, 02:18 -
HowTo encode videos to High Quality on YouTube? Currently using XviD4PSP
By guy24s in forum Video Streaming DownloadingReplies: 15Last Post: 27th Sep 2010, 23:41 -
xvid4psp, help, how to encode for DVD player
By betalb2008 in forum Video ConversionReplies: 1Last Post: 17th Jan 2009, 18:15
